TunerLanding
Assuming one has an appropriate tonearm and MC preamp capabilities is it true that a moving coil cartridge will generally sound superior to a moving magnet catridge at the same price point?
Not necessarily, especially if the MM cartridge has a better stylus profile. I can name at least a half dozen MM carts I prefer over, say, the more affordable Denon MC carts in the same price range.Assuming one has an appropriate tonearm and MC preamp capabilities is it true that a moving coil cartridge will generally sound superior to a moving magnet catridge at the same price point?
S Finally, the highest levels of moving coi cartridges will not have an equivalent in the moving magnet realm.(...)I
And the manufacturer can always reduce the size of the magnet even further and add more turns of wire to the coil to compensate .
LOL, you're special !Where does my Pickering XLZ fit in ? It's a LOMM. Stanton also made one the 981 LZ. I feel so left out.
I voted yes, however I feel I need to qualify my answer.
...I also don't have any experience with exotic carts, like in the 000s range. And my experience with MC carts is limited to a few models from Ortofon and Denon, i.e. real life examples...
...I feel that a good stylus has more influence to the sound than comparing MM and MC...
...But, the elliptical and fine line styli on Ortofon carts that I have and listened to is much better for classical, Jazz and acoustic instruments. Meaning, I'd rather listen to a MI cart, like the Stanton 681 for Rock and Pop music....
...One other aspect, really important, is matching the cart to the tonearm and the pre-amp loading. I can understand the mechanics of both these parameters but could not really appreciate the impact until I listened and compared.
NoAssuming one has an appropriate tonearm and MC preamp capabilities is it true that a moving coil cartridge will generally sound superior to a moving magnet catridge at the same price point?
Let me start by saying I was a "MC cart snob" years ago, when I was young and could not afford one. Until I, accidentally, got hold of one with an Ortofon step up transformer.
And a "lowly" Ortofon OM30 is a pretty good performer as well.
I was recommended not to use a Mc coil on my dd table because of the lower output would require higher volume levels which would show more noise from the table , don’t know if it’s true but seems to make senseNot necessarily, especially if the MM cartridge has a better stylus profile. I can name at least a half dozen MM carts I prefer over, say, the more affordable Denon MC carts in the same price range.
As you go up the chain and get into crazy price territory, I'm sure things change. But for most of us with real-world budgets, you can't really generalize like that.
