kbwhaaland
^My Audio-Technica VM540ML creates more hiss into the MM input of my Cambridge Audio Alva Duo phono amp than the AT33PTG/II does into the MC input. I didn't expect that at all.
Don't know about all of that, but it will track the Telarc 1812 with ease!
The twin magnet ATs have a suspension system similar to MCs with a defined pivot axial tie.A side issue is how well the listener hears. As a senior with some tinnitus. Guessing I'm not the only one here. I don't expect to hear a lot of what the best carts do. That ship has likely saled.
I have a Nagaoka MP200 with boron cantilever. On an old rebuilt LP12 with Basik LVX arm. 834 clone MM preamp. It's the priciest new cart I've had. Never had a MC.
Pearl is a fun cart. I listen to it often even though I have more technically superior carts in the stable.My table is a lp120 audio technica while a decent table I doubt I would get the real Benefit of a high end cartridge ! I have a sumiko Pearl which seems to work well with this table again a nice affordable table but not high end by any means ,
At present, I do not own a phono stage that will accept typical, low-output moving coil cartridges, so I haven't looked into them for quite some time, but I see that AT by itself offers eight such cartridges within a $259 to $789 price range (USA dollars; 2M Black is $695 USA). Ortofon has its Quintet line that offers four models ranging from $359 to $999. I know there are others, such as the Denon DL-103 ($349) mentioned earlier in the thread, so yes, there does seem to be a fair amount of overlap between moving coil and moving magnet price points.I think there’s a fair amount of overlap, one of my carts is an ortofon 2m black 900$ or more CAD.
The DL-103 is one of the few moving coil cartridges I've been curious about. Sadly, no dealer I've ever visited has had one mounted up for audition. Herb Reichert mentioned it in the course of his comments on the AT-VM95C:I'm not sure that a "price point" has anything to do with how audio products sound. My prefered MC cart is a rebuilt Denon DL-103, what can you compare that to?
I have its older brother the AT PL120 with a sumiko pearl and it’s a good match ! A lot of bang for the buck this table got me back into vinyl ! Is it perfect no , is it audio file no , but it’s a very user friendly table that sounds good !At present, I do not own a phono stage that will accept typical, low-output moving coil cartridges, so I haven't looked into them for quite some time, but I see that AT by itself offers eight such cartridges within a $259 to $789 price range (USA dollars; 2M Black is $695 USA). Ortofon has its Quintet line that offers four models ranging from $359 to $999. I know there are others, such as the Denon DL-103 ($349) mentioned earlier in the thread, so yes, there does seem to be a fair amount of overlap between moving coil and moving magnet price points.
My one and only purchase of a moving coil cartridge was in the late 1980's, and was a Linn Asaka purchased for my LP12/Ittok. I liked it, but not enough to continue with moving coils after its stylus was worn out. I've always gotten plenty of satisfaction from modest moving magnet models (under $150, and mostly under $100). Getting great sound from low-cost cartridges was the reason I bought a Linn in the first place.
"I have a BFF relationship with the spherical-tipped Denon DL-103 moving coil, simply because it has never disappointed me while playing a record. The late Art Dudley campaigned for the spherical-tip cause, stating in Listening #186: "I continue to prefer the spherical experience—to me, it emphasizes musical content over air, allowing instruments and voices to sound more substantial, and music to sound, overall, less fussy than with other tip types." (The emphasis is his.)"
https://www.stereophile.com/content...io-technica-goldring-lp-gear-phono-cartridges
You asked what can you compare that to, and while the OP is interested in equally priced cartridges, I would be more interested in seeing if the DL-103 offers any sonic advantages over the $79 Sumiko Oyster (replacement styli just $39), which greatly impressed me even on my lowly AT-LP120XUSB running into the built-in phono stage of an Audio by Van Alstine OmegaStar preamp.
Regarding the last post about not using a MC because of more turntable noise. it's basically false, because the mechanical noise would be a linear function. for example, you play the record, and the volume is X, that volume is still basically X at the output regardless of the cartridge. so therefore vibration noise is the same ratio for either cartridge. The preamp for MC has more gain, but the output is still X. For example, 10% mechanical noise will still be 10% mechanical noise,
I understand cartridges themselves have a residual electrical noise
Dead tie !
I didn't vote either. You have to love the inexpensive MM stylus replacements and near zero wait time compared to MC replacements.
