Good catch, sometimes you can look right at something and not see it. At times you would not believe the checking I do before I solder in the transistor. I'd rather sweat getting it in right, rather than figure out what the $#@# went wrong...
I'm blind to my own spelling errors....
And as you have seen, I occasionally reverse number pairs.
My "trick" for a triangular lead arrangement is to align the two end wires with their respective contacts, then bend the center either right or left to it's hole....
for neatness sometimes I scootch the whole shebang over to center it a little more attractively on the triangle.
I would still check the diodes, just in case, because the (raw dc = +78.8) +60 was also running on just one (FU2) fuse, and IT'S voltage was LOTS better.
Once you have it running again, please measure the voltage ACROSS R1 and R19 those 10 ohm multi-watt resistors, knowing the resistance we can calculate the current being drawn on both supplies. It could be the - voltages are being loaded down somewhere. This is one of the few instances where ungrounded voltage meaurements are taken.
nite nite, I'm toast... sigh ning off till tomorow.
