Analysis:
Thank you, Jack. Your work with these A-25s is enlightening, and much appreciated. I hope that others with these capabilities will replicate your studies and post their findings here. :yes:
I asked Jack to measure with the microphone on axis with one of the tweeters so that the "listening" perspective would be held constant. That also guarantees that there is some difference in distance from each of the other drivers, which is what generates the phase anomalies, both interference and reinforcement, which also vary with frequency.
1)
Horizontal, in-line - Looking at the bass first, and using 80 Hz as the reference, I do not see any enhancement in bass extension. As with the original measurements, the response drops linearly by 20 dB from 80 Hz to 28 Hz, the band between 25 and 31.5 Hz. However, mutual coupling is occuring, and the bass is now balanced with the midrange. Compare 80 Hz with 1 kHz. It was down 3 dB in the single speaker measurements, but is equal when the two are playing. Clearly, the response between 80 Hz and 1 kHz is now flatter due to this, and smoother due to averaging of the two sources. Better bass, the woofers are working together.
It all falls apart between 2 kHz and 10 kHz, however, with a 10 dB deep full-octave wide hole in the response caused by phase interference. I suspect the crossover is somewhere around 4 kHz. This anomaly is major; the speakers may as well not be playing those frequencies at all.
Comparing the very high frequency response of the original measurements of singles, which are basically a shelf at -5 dB from 12.5 kHz up, the highs are rolled off when stacked. There are likely more adverse combing effects going on in this range as well, but the RTA does not have sufficient resolution to display them. See the link to my study below.
2)
Horizontal, opposed - While the notch at 4 kHz is no worse than in the original measurements, combing ripples are apparent in the response above 400 Hz as compared to the #1 stack, and the VHF rolloff here begins at 10 kHz. I can't really see 20 kHz because of the reflection.
3)
Vertical, tweet to tweet - The midrange ripples have moved lower, here beginning at 160 Hz, and the VHF rolloff begins at 8 kHz and falls nearly 20 dB to 20 kHz. All tweeter sizzle is gone.
4)
Vertical, woof to woof - The woofers are now close together and there is phase interference at low frequencies, as well. I have no explanation for that; the woofers should be summing as in #1. The flat response of the other configurations is gone above 80 Hz, there are 10 dB holes in the response at both 1 kHz and 4 kHz, and the VHF is rolled off above 9 kHz. "Sucks" comes to mind.
In fact, there's no determining which configuration is best. If Jack were to move the microphone as little as one inch, the pattern of anomalies would be different, and depending upon the position of the listener, the full range of them would occur with any of these setups.
What IS apparent here is that playing both woofers enhances the bass response and balances it better with the midrange. Turn off one of the tweeters, and some of the problems will disappear. However, that scenario should be analyzed in the various combinations as well to determine the optimum configuration.
My recommendation would be the same as Jack's: Use singles against the wall or in corners for boundary bass enhancement; add a sub if still more or better bass is desired....
http://audiokarma.org/forums/showthread.php?p=1138398#post1138398
Also see
2: Demonstration of principle here:
http://www.jblpro.com/pub/technote/fat_wht.pdf
When two sound sources producing identical program are displaced relative to each other, they will combine to produce a unique interference pattern that depends on the observer's location. The interference pattern is a result of the different arrival times from the two sources.
