Nobsound E6 Preamp Uses Directly Heated Tubes
Sorry for being late to this thread.
I've had the Douk E6 for some time now running it of a "beefed up" mobile charger - although still being "only" 5 Volts.
I'm to receive a variable SMPS with up to 35 volts 5A supply. Have you any experience with giving the E6 more than the recommended 5 Volts?
Have also bought the russian tubes from Ukraine. And next step will be replacing the 4 grey square coupling caps with something better. Said to bring this lil' marvel a lot closer to near high(er)-end. Well see...
I found that upgrading the caps and the tubes made a bigger difference for the better compared to the LPS that I added. The recommended wall-wart PS or LPS would be better than a SMPS which can be noisy and I would steer clear of them.
You'll find a number of posters that changed the coupling caps, me included. I didn't put a Linear Power Supply on the E6. I just make sure it's always in a fast charging phone port to get 2.5A. Since I never used a LPS, changing the tubes to the Russian model was the most noticeable improvement. Altho I changed the caps, I felt like there was little change. The change was more noticeable when I did the coupling caps in my Tube03 unit. But right out of the box, I preferred the sound of the E6 and still have it in daily use in my school system. The Tube03's with the mods - coupling caps, opamps, and tubes are all in daily use in other systems.
Look forward to hearing how you think it sounds with the cap upgrade.
Running off a power supply that’s higher than 5v would likely destroy it unless it has some built in over-voltage protection circuitry, which is unlikely. Parts are spec’d to work with a 5v supply source so if they see higher voltage some will fail. You wouldn’t plug an amp that’s designed for 120v wall voltage into a 240v outlet would you?
Your “beefed up” charger that can supply more current won’t hurt anything as long as it’s 5v. But I can’t imagine why using a power supply that is capable of supplying more current than the recommended 1A would make any difference. The total current draw of each tube is only 4mA - that’s only 4/1000 of an amp - and each tube’s heater only draws 56mA. The current draws don’t change just because the 5v supply is capable of supplying more.
Different output caps will alter the sound to some extent but the operating points of the tube have a much larger effect on the sound than caps. The voltage / current used by the tube is the operating point. None of the inexpensive Chinese preamps, including the FX types and the E6, are amenable to changing the operating point of the tubes. And the operating points they use seem to have been chosen based on economics, not sonics.
If you want to go beyond basic tube rolling and cap swapping you’ll need to build something yourself. Doing so will allow you to have full control of all performance parameters including the ability to experiment with operating points.
I recently posted a DIY preamp design that’s aimed at those who might want to take that next step:
I was asking because I have read that the electrical power supply can contribute to the hum the e6 can have. So I wondered if a DC power supply might help reduce it.
The issues some have had with hum / noise is usually related to the particular tubes used. The Russian ones seem to be better than the stock Chinese ones in this regard. Have you tried using different tubes?
That's the first thing to try if you have hum.
I suspect that whatever you read was posted by someone who thinks the tubes are being heated with AC voltage. Directly heated tubes can be more prone to hum / noise if heated with AC.
But power to the E6 is provided by a common USB charger / supply which has an output of 5v DC. So there is no AC used anywhere in the circuit.
As I recall, Nobsound only supplies a USB cord, not the supply itself. If you've tried different tubes and still have a problem then it's possible that the power supply you're using is noisy. I suppose you could experiment with another type of supply as long as the voltage going to the preamp is 5v DC and can supply a minimum of 1A. Maybe also try a different cord.
Swapped the 20uf cap today for a 2.7uf and it now seems to have more treble and less bass; less boomie and more fizzy. Initially added 2.7 to the 20. Might try 1 and .047. Still experimenting. Listening. Trying to squeeze out treble to my liking. without an oscope ,hard to prove. Might be becoming accustomed to the sound.
Okay! At 1uf the sound has more treble. Not there yet, though. Tried .47 and the amount of hiss was unbearable, unstable, while playing miles davis' flamenco sketches. Currently at .68uf. much better now. Stable and minimal hiss. Will stay at .68 for now. Wonder how an oscope shows this. Can now hear background of a symphony orchestra preparing to play. Bass still a plenty playing los lobos.
Looks like the cap you’re messing with was originally the electrolytic that’s marked as C14 on the board, correct?
If so, that one seems to be in the power supply, not in the audio portion of the circuit. If it was in the audio portion of the circuit, there would be two of them with identical specs, one for each channel.
Caps in the power supply are used to filter out noise.
That’s why you got hiss when you changed the value. If the change in value was actually boosting the treble from your source, that would indicate that the hiss was also coming from the source. So either the recording contains a high level of hiss or the source component is extremely noisy. Both situations seem unlikely unless the hiss is also present when listening without the preamp.
Replacing an electrolytic, especially a cheap one whose quality may be questionable, with a film cap may yield some audible improvement but it’s best not to change the values of components when you don’t know what part of the circuit they’re in or what role they play.
The power supply in the E6 takes a 5v DC input and boosts it to 105v.
According to the blog that Lenco followed when replacing the four 1uf 250v gray caps (Doctorjohn Cheaptubeaudio), the boost circuit is a switch mode supply. The blogger, who has since passed away (RIP), asked but the manufacturer would not supply a schematic. I don’t know the technical details of how the voltage boost is accomplished, but I do know that switch mode supplies have high frequency switching noise which must be filtered out.
A commonly used element in a power supply consists of a series resistor followed by a cap to ground. This configuration forms a low pass filter. The rolloff point created by the filter allows anything below the rolloff frequency to pass and filters out the high frequency noise above the rolloff point. It’s not a hard cutoff, it’s -3db at the rolloff point then it drops gradually.
In such a filter, if the value of the cap is lowered the rolloff point goes up. This would allow more of the high frequency noise that’s generated by the boost circuit into the supply voltage for the tubes. That’s why you get a lot of hiss. If the hiss is not part of the recorded audio signal then it’s not coming into the preamp via the inputs. It’s noise from the power supply.
If you want more treble, it’s the high frequencies in the audio signal that you want to boost, not power supply noise. Just use an EQ of some sort between the source and the preamp. An EQ boosts or reduces the strength of the various frequencies that are actually present in the audio signal.
From the pics I’ve seen there are four electrolytic caps. The two in the middle are not the same size so I assume their values are different. Those are the ones in the power supply boost circuit.
The two smaller ones, which seem to be the same size, are located towards the ends of the board. Those would be the cathode bypass caps which are part of the audio portion of the circuit. If I’m correct, you’ll find that they are the same value and voltage. Value will typically be relatively high and voltage will probably be relatively low compared to the caps in the power supply. You can use the continuity function of your meter to confirm their role. The + of each cap should connect to either Pin 1 or Pin 8 of the nearby tube.
If your treble is rolled off it’s more likely due to the PIO caps, which are typically not as bright as film caps. Two of the original gray caps are input caps and two are output caps. Again, one per channel using the same values. According to the blog, the ones labelled C2 and C3 are input caps and the ones labelled C1 and C15 are output caps.
The purpose of an input cap is to block any potential DC that might be on the output of your source. Most sources already have DC blocking caps on their output. If there is no DC, and there shouldn’t be, then there’s nothing to block and you could just remove the input caps and replace them with a wire.
I’ve never actually come across a source that outputs DC that needs blocking. There would likely be hum if there was any. That’s why my most recent preamp build, which I linked above, does not use blocking caps on the input.
The other two (C1 and C15) are output caps which block the DC voltage on the tube’s plate from the output that goes to the amp. You measured 65v on the plate previously so one lead of each cap should have 65v on it and the other lead should have 0v DC. The cap in series with the signal followed by a resistor to ground form a high pass filter.
If you use the resistance function on your meter and measure (with unit off) between the 0v lead (or the center of the output RCA) to a ground you can determine the value of the resistor. Then we can calculate the -3db high pass rolloff point of the audio signal at the output.
As has been pointed out, both by me and on that blog, with these little commercial preamps you’re limited to upgrading the quality of a few caps. It’s kind of like wanting to make your car faster but the only thing you’re allowed to change is the tires.
That’s why I keep suggesting that people who are into modding take the next step and try DIY. This gives you total control over the entire circuit, not just the “tires”. Preamp circuits like this are as simple as it gets. Breadboard . . . experiment . . . build!
I hear you. Pio cap mod is from other member. I'm just pointing out my findings. Sound was initially dead silent, no treble; but got a lot more treble, plus a bit of hiss, dropping the 20uf cap considerably. I've actually been listening to it for the past week; whereas before, it was intolerable. I'll go over your post and see what I can implement. Just playing around with this unit and the fx 03 currently, until weather cools off here. Then I'll move on to something else. Thanks.
Okay! Implemented some of the suggestions: film caps are brighter and bypassed the input caps. Had to increase the initial 20uf cap to 10 from .68, as hiss increased. Much better on the treble for sure. It's cooled off here significantly, so time to finish a Yamaha c-2's power supply. Thanks everyone.
Have been listening to the e6 since 9 am and it's now one of my favorite pre amps. Settled on a 10uf/400v polar cap and two 1uf yellow film caps. Sound's fantastic! Thanks everyone.
...the FX Audio Tube03 is fun to play with.
I am not trained and am not familiar with the jargon, sorry. Can someone provide more specific labels for “10uf/400v polar cap and two 1ut yellow film caps” for those of us not familiar with the terminology? Thanks. And apologies for lack of knowledge. I am interested in trying this mod out.
Maybe try to dm @raycarr00 . If he doesn't see these posts. @FlaCharlie can definitely give you info too.
Reading that post i think the following.
The 10uf/400v polar cap is a 10uf capacitance capacitor with a voltage limit of 400vdc, being 'non polar means it only works installed in one orientation, likely a electrolytic capacitor.
The 1uf yellow film cap is 1uf capacitance film capacitor, the film is the dielectric, these caps work installed in either direction, but some types work better in rejecting noise when installed with the outer foil side connected to the lower impedance side of the circuit.
Pic are not working otherwise I would post pictures of the different types of capacitors, but you can google information of capacitors easy enough.
If anything I posted is incorrect the original poster can correct.
Thank you
