Those spring clip speaker connectors on that Sansui hardly say "high build quality". It would seem to me that any device using them is not in the "high build quality" category.
A 'real' Yamaha amp
Here's a few suggestions for determining build quality in analogue amplifiers:
Minimal use of moulded plastics, for cosmetic, operational, structural or support purposes.
Significant use of metals for chassis, casework, control knobs and shafts, internal supports and bracing and/or external support structures.
Signal path minimization via strategic placement of switching using high quality components.
Minimal use of multi-way connectors, ribbon cable, unshielded cable, surface mount componetry, monolithic integrated circuits.
Usage of high quality components from reputable suppliers.
Elimination of noise from micro controllers or removal of unnecessary CPUs and/or digital electronics.
Significant reserve capacity in transformer, rectifiers, main filter caps and all associated PSU feed wiring over and above the rated/designed performance targets.
Low impedance PSU lines. busses and output feeds.
Significantly over-engineered output stage to allow for virtually any conceivable load without destruction or premature shut-down.
With the amount of times you've typed AU-2000 on this website,
So much for build quality. What is it with you guys and Asian products anyway? N. American made has always been better(looking too). Okay, maybe not McIntosh(looks, yes. Sq, no). Never liked that one. But the rest blows the Asian market out of the water. Always has. Especially if you include the Brits(Aussies as well...OH OH).
He's been typing AU-20000, different beast.
I have to say that i think the hi-fi manufacturers are pandering to these rich people who will buy this stuff, they could easily build that amp for less but why would they when they can sell it for $$$$$$ rather than $$$
Yeah, no good amp has ever come out of Japan![]()
Post pics of a modern amp that meets all of restorer-john's points, and it'll likely be labeled as "boutique" and "audiophool".
With the amount of times you've typed AU-2000 on this website, I could almost picture you on one of those "my unique obsession" TV shows caressing and kissing your Sansui after pouring a glass of wine for yourself and another for the amp.
Maybe it's just me, but the internal shot of that Sansui doesn't make me say "wow, look at that build quality!" (nor does an exterior shot).
Easy there big fella. I was referring to the one Steve Huff brought back shortly after raving about it. I didn't say they're not good. Just that pretty well all the other non-Asian major manufacturing countries do much better. I would however like to have a listen to a Yamaha MX10000.![]()
Denon, Onkyo, Yamaha, Luxman, Hitachi.. etc etc Have all built and some continue to build amps that rival if not better anything put out by anyone else.
Just a simple fact... For instance I think Audioholics uses the Denon POA-A1HDCI as their reference amp.
Those solder joints on the green board look pretty poor.
