Looks great! So when are you free to up here and do mine?
Yamaha B-2 said:Nice work! :thmbsp:
How did you manage to pull out the six (6) parallel caps on the right of your first picture out of their sockets? I was afraid of breaking the plastic when I tried. But will eventually get around to it.
I used 14ga DHLabs to rewire the set that wajobu has. Was very happy with the results. Changed out the terminals to the cheapies that PE sells, but are better than the horrible things that are stock. Just have to do the NS-1000 I now listen to.
No problem on the tweets. Just give me a shout when the time is right.
Great job! Makes me want to go and do likewise.:thmbsp: :yes:morksbeanbag said:What do you all think?
the-real-mandak said:Regarding the Soavo they seem interesting, now we just have to wait until they get vintage and we can get them cheep![]()
I'd be real curious to hear about the final sound test once you get a replacement OEM tweeter.Know anyone who might need a Left side NS-1000M cabinet..Ive got one just collecting dust.:scratch2:I changed out the old electrolytic bass caps with new SCR and wilmslow supersound polypropylene caps, the old ones were both 47uF 50v making 94uF. I used a 39uF, 51uF and 4uF giving the same rating but with much higher voltage capability. The electrolytics i took out felt light, usually a sign they are dry.
All wiring was swapped out for flexible Gale OFC cable. The wiring for the midrange cap bank was replaced (the old stuff had started to corrode. I replaced this with laquered copper wire with the laquer scraped back only where needed. The large caps were held down with cable ties. The tweeter 2.7uF was moved to the underneath of the board as it wouldn't fit on top, the thin old linking wire connecting the tweeter signal across the board was replaced with a chunkier copper bus bar stolen from an RX-V800 power amp board.
The evil springclips were replaced with some good binding posts from a pair of Eltax symphony 8.2 speakers. No plastic parts on them.
Any loose peices of potential holes out to the back (near the binding post board) was covered with epoxy resin to seal everything.
The L-pads were given a good polish and clean.
Sold cabinet to AKerKnow anyone who might need a Left side NS-1000M cabinet..Ive got one just collecting dust.
