PickyEars81
I wondered about the dullness of my solder. It seemed to take forever to heat the component enough to get the solder to melt at all. I did heat it from the other side of the work, but still...
What temp would you suggest I set my station at next time? And how long would you expect it to take before it melted Cardas solder (it states 338°F)?
The temp will depend on the solder - I use silver solder for things like this - YMMV. I don't have a nice enough iron to set temps - mine is cheap and has a 15/30W switch. I would set mine on 15W, get the contact securely together (so that minor movements don't separate it - use a vice if necessar0 to secure the main board) then heat the two components (wire from cap and contact on the board) with the iron while simultaneously pushing the solder in between the joint, but not actually touching it to the iron. Make sure not to melt the board, but the contacts should eventually (quite quickly actually) start to suck in the solder - feed a bit still it makes a nice nipple, then pull away the heat.
