Frank Solem
Hi
Felt like the luckiest guy on the planet, got hold of a very nice TA-1120, the original without the headphone jack. With a original, also nice wooden box and pristine faceplate.
I guess it has been a problemchild, since the power amp was bypassed, and previous owner tried to use it as a pre. I bought it as a none working unit.
I have reversed previous job, so its back to original now.
Replaced all ecaps and 2sc401 trans. Pulled the rest of the transistors and checked them OK. The problem now is my silly brain I guess. I get crazy voltage readings. C505 has 40v on + (should be 23v), but also 33v from - on same cap to ground.
I have been re-checking the transistors, checked resistors and diodes all over. But I just dont understand. I would guess it had to be a ground issue, but it seems to be OK.
It reacts quite normal when i hook it up to my DBT and the relay clicks in after 5-6 seconds.
The power on the main cap is low, but im guessing that is partially DBT and partially related to the other voltage problem. Main cap voltage sits around 70V.
All output transistors have the correct voltage range compared to the main voltage, except the pair to the very left. They are 10v to low. The rest is 70V and 35V.
Edit, just remembered, there was a open diode in the rectifier bridge when I got it. I changed all four.
I have checked the trafo, it delivers 240V.
Advice is gratefully received
Pictures can be posted
The last culprit was C114, a 100pF film cap in the equalizer section. I usually dont change film caps, so..
