Hi again! I feel i owe you a update
After my last post, i felt it was time so assemble everything and try it on the bigger speakers again.
After putting everything back together, I tested on DBT, all voltages seemed good.
I wasn't too confident, so I plugged it into the mains 240v without speakers and blue smoke came from left main amp board. It was all four emitter resistors that gave in.
I changed them out, measured the output transistors, and had to replace two of them.
Tested the rest of the transistors and diodes on the board and they all tested fine. Also checked all of the resistors against the healthy right board.
Testing again on DBT, plays nice, but when i measure bias over the two upper emittor resistors(R224&R226), I get 1,6mV.
When i measure over only one resistor, i get 22mv(guess that should be closer to 50mv, but I still run with a low bias). If i measure the bottom pair R223&R225, i get 15mV, as I want to have on the DBT.
Isn't that a bit strange...
I was thinking it had to be bad solder joint where the wires goes out from the power amp board. Thats where I measure bias, easy access. But I touched them up with same result. Also when I measured on solder joints over both resistors, 1,6mv.
Single resistor measurement 25mV.
Wait a minute, there is a diode on the printside of the board, connected to the emittor resistors. I havent measured that one!... It measured fine.
I will post again when i find the fault.
Oh, I forgot the most important thing. When I feel brave enough to connect to the mains again, is there anything i can check to make sure I dont get magic smoke again?
Turned out the last short was also due to my soft mica plates on the output transistors. I will swap with oldfashioned hard, thick silica plates.
