Home Blown
I had a 1970 Chevelle 2 DR. HT. that I inherited from my folks that had bought it new. It originally had a 307, 2bbl V8 (that is a V-8 with two bubbles). Over a number of years I changed the entire drive chain building up all the components myself except the fully manual TH-400 transmnission that I had a shop do for me. Final result was a 350 with a 671 GMC blower, 2800 stall converter, 3:73 Posi, quad 2-1/2" exhaust. The blower package was entirely home built from a diesel blower I found in a junk yard. I fabricated the manifolds and drive all myself. I used 1/2" pitch Vega motor timing belt camshaft pulleys (which I removed from 4 Vega motors at a junk yard) in parallel for the 2" gimler belt, used a cast iron Q-jet manifold with a box brazed on top with a burst gate valve on it with a big 3/8" steel plate to bolt the blower to. Instrumentation up the ying yang on the back of the blower outside of the cockpit reading vacuum/boost, oil pressure, fuel pressure, pilot lamps for two stages of water injection, soap, rinse, spin, etc. Homemade 4-link underneath. Quad shocks on the back, 90-10's on the front. Truck springs in all 4 corners for lift. Homemade 10" steel rims on the back (had access to a BIG lathe). Dual batteries in trunk for more ballast plus fuel cell, electric fuel pump directly below. All Aeroquip steel braid hydraulic hose for liquids. This 3,500+ lb. baby went 0-60 MPH in 4.2 seconds on street TA's. It also did 0-60-0 in 300 feet, and all it had was manual drum brakes! If I had had the money for real aluminum wheels and some other real speed equipment it would have gone even quicker but wouldn't have been any more fun. I spent days crawling around underneath with a sandblaster (taking the body off would have been a lot easier) and painted the entire underside in black rust paint. Topside I painted it Federal Safety Yellow with a roller! The day after I'd painted it I was in a parking lot of the local hardware store and a fellow auto enthusiast with a custom truck parked beside me and admired my paint job which still smelled fresh and looked great. He asked me if I had clear coated it. I replied "No, I only had one roller!"
All true! Times got tough 10 years ago and I had to sell it. That car sure was fun. The turbine whine from the blower idler pulley could be heard a block in front of where I was headed. It sounded like you were at the airport.
BTW, a carb with small primary bores and large secondaries is called a 'spread bore'. I was running a small 600 Holley quad square bore on my stuffer with vaccuum secondaries.
This was just the last of a long procession of self customized wheels I've owned and wasted my money on starting with motorcycles at age 16 (a Honda 305 Super Hawk). This was the last, and most significantly the first where I built most of the speed parts myself instead of buying them. I didn't send a single piece out to get chromed. Really did this on the budget side. It was much more personally satisfying too! I have all the tools but now am so tired of getting my hands dirty that I don't even want to change a flat tire anymore.
Been there, done that, got the t-shirt but the damned picture eventually washed off.
Rob
