Update:
Over the past month I've been playing with various cheap DIY kits, like an LED clock, a pocket calculator, an hourglass (different from the one above, and this time I didn't mess anything up), a game console, a pocket FM radio (no video of that, sorry), and a few other things.
I am now confident I can tackle any THT soldering job without breaking a sweat. I get perfect joints every time. As for desoldering... I do occasionally encounter a stubborn joint, but in the end I manage to defeat it one way or the other. While as recently as two months ago I dreaded soldering and was completely useless at it, now I can do THT with my eyes closed.
So, I thought it was time to move on to SMD.
The first technique I had to learn, and quite early on at that, was drag soldering, because I needed it for the hourglass I talked about above. This was pretty easy. Somehow I got the hang of it immediately and never had an issue. At first I used to tack two corners of the chip and then solder the rest, but now I can skip that step. I can easily hold the chip in place with one hand, with a pair of tweezers, while loading the soldering tip and then dragging it across the legs of the chip with the other.
OK, so SMD chips are easy, but how about those tiny resistors or capacitors that you can barely see with a magnifier, let alone with the naked eye?
First, I tried to apply the same soldering technique that I used with THT. This kind of worked, to an extent, but resulted in big blobs of solder:
Horrible. Yuck!
The problem, I realized, was that the 0.8mm solder that worked so beautifully with THT was much too thick for SMD. No matter how gently I tried to touch the component with the solder wire, and how quickly I tried to withdraw it, I just could not get that teensy-weensy amount of solder that I needed.
Obviously, SMD required thinner solder wire. So I went ahead and got some 0.25mm.
Now we're talking! No more blobs. Now I can feed the wire slowly and controllably without drowning the component in solder.
It looks much better. Not quite perfect, mind you, but definitely presentable.
But the trouble is, it's extremely fiddly, takes a lot of time, and doesn't always turn out that nice-looking. It's a bit hit and miss. Maybe with more practice it would become more hit than miss, but deep inside I wasn't entirely satisfied. I can do it if I have to, but I would be happier if I could find a better method.
The more I read about SMD, and the more videos I watched, the more convinced I became that in order to master SMD one needs a hot air station. Sure, you can do without if you really have to, but it makes life much easier (or so it seemed). So, I got myself a relatively inexpensive, but seemingly well regarded, hot air station and got to work.
A tiny bit of solder paste on each pad, then carefully placed and aligned the components, then hit them with the hot air. And here's the result:
I did them in batches of three or four, covering the already done neighbouring components in aluminum tape to protect them from the heat and keep them from melting again.
I made sure that the values printed on the resistors were always aligned with the labels on the board. And when this was not possible, at least I made them face the same way. I do this with THT, too, I mean I place all resistors so that their colour bands have the same orientation. You can tell I suffer from OCD, can't you?
Of course, nice-looking joints mean nothing if the device does not work. But fortunately it does:
Horrible. Yuck!
