I spent some time tonight getting measurements, and I've ordered a power IC and predriver IC for the bad channel. It appears someone had removed the bad channel predriver at some point and wrote "good" on the back of it. So I'm guessing they pulled, tested, put back in. The solder job was okay, but 13/14 was bad. I just pulled.
Then I pulled the power IC.
I checked the "burnt" resistor and it is fine.
With both IC's out in the bad channel, the receiver now powers up out of protection mode as it should.
Emitter resistors all measure fine. One is a goofy tall one. Being anal, I may order a new set of four, just to do while everything is apart.
I measured pins, single, two, and three diodes on the Power IC. The problem pins are 6-8. There is a bad diode in there.
At this point, I feel pretty good this should do the trick. I'll report back in a couple weeks, or whenever the predriver from Utsource arrives. They have a message about heavy rains delaying shipping. I got the power IC from Suburban and paid an extra dollar to get priority.
I appreciate all your help and will be back when it's done. :thmbsp:
