EDITED:
Post #167 through to #227 are all between the gentleman CHAZIX and my good self. Summarised for your benefit, click here to skip this long conversation and see the result and rejoin this thread.
I just picked up a CR1040 very cheap. Works, but the tuner face plate is a little rougher than i would like. Anyway, its in working order...other than no lights at all...light kit from ebay on its way...and the tuner knob is misaligned.
I would like to buy the parts now and shelve them. How do i find the ones you are listing?
Anything else i should buy to future proof this amp? The relay was making a bit of noise when i tried to run my cerwin vegas from it...are they easy enough to find.
Is there a servicing guide for them...i will open it and clean it when i do the lights...what else is normal maintenance for them? I can do anything mechanical like soldering and welding, but less so electrical.
Cheers
PS: anyone got any thoughts on perfect match speakers? I tried on jamo concert 7s and cerwin vega e312 and the relay clicks in and the overload light comes on when i go past 1 oclock on the volume - is the best best to use it as a phono stage? How do i play i loud?
PPS: i notice a sticker on the back saying it had been repaired when having no audio out...interesting.
Tom B mentions CR-1040, but seems to be describing the CR-840 module set?
Also, installing IG02950 (CR-640 predriver) in place of IG02940 (CR-840 predriver) is risky. If we assume that they really were different modules, the IG02950 might not be able to withstand the full signal voltage swings that an IG02940 can. For receivers that aren't ever going to be pushed to near their maximum output, it probably doesn't matter if you make that substitution.
If anyone does need safe, drop-in replacements for CR-1040 or CR-840 predrivers, you can find my pitch for repro modules in BarterTown.
Cheers,
chazix
Cheers
