Onkyo A-8450?
maskof
Hello friends,
I would like to hear your feedback regarding the Onkyo A8450 amplifier. Is it a good choice for peak performance, or should I consider alternative options?
@maskof
I see you're relatively new here, less then a month, so you might want to review the AK rules.
See #4
You already created a thread on this topic earlier today, creating multiple threads on the same topic is considered a no-no.
I'm assuming a Moderator will be by soon to delete or close this one.
@maskof
See #4
Sorry, sir. I didn't know how to delete the old one because I was confused about which side I should post on. Really sorry.
I love onkyo gear myself, find it very hard not to. Great specs, very low distortion, plenty of power generally good build quality etc.
Looks like a very nice integrated amplifier to me
Hello friends,
The A-8450 is a decent integrated amp, and Onkyo made good stuff in the 80's, but I do not understand your meaning of "peak performance" ? It all depends on the rest of your system- what speakers do you have, what kind of inputs (streamer/CD/tuner/phono/etc) do you plan to use ? The A-8450 integrated amp only puts out 80WPC and was made 35 years ago, so it will likely need new speaker protection relays and new capacitors. I rebuilt my Onkyo M-508 amp (that I bought in 1986) just last year and had to replace all the capacitors, some small transistors and all the output transistors to make it reliable again.
This M-508 (200 WPC) is closer to "peak performance" than any of Onkyo's integrated amps, but it is only middling by todays performance standards, because it doesn't put out a lot of current like todays amps do. It cannot drive low ohm load speakers for very long before it shuts down- my Infinity RS4b speakers drop down to 3.2 ohms and would send the M-508 into protection quickly at high volume levels.
Thank you very much for the valuable information. Thanks, sir!
