Feed direct and listen
Thank you. Definitely something to consider.I'm using this.https://www.xkitz.com/products/linkwitz-riley-2-way-active-crossover-xover-2?variant=32767760910 Bi amped with 2 SET amps. Enough volume for us.
Thank you Poultrygeist. If I go for a Yung, I won't go for anything bigger than the SD100 then.
Looks good but for $79 you can buy a plug and play Behringer 2 way which doesn't require purchasing a power supply, a case or a module to change the crossover frequency.
Hi PG the baffle you have on top of the h-frame with the FR on it, is there measurements of mounting whole location?
The dimensions of the inverted T baffle atop the H-frames is approximately 19" X 19" for the base ( just a continuation of the H-frame 19 X 19 X 19 cube ). The erect baffle where the FR drivers are mounted is 19" wide x 24" high which allows them to be at ear level when seated. As for driver placement and off set on the baffle I followed MJK's model.
My big order from Parts Express should be here tomorrow! I have ordered a pair of Alpha 15's, a pair of ASD 1001's, a pair the horns you and Godzilla used to go with the 1001's and the $80 Berhinger. The cables I need came today from Monoprice. I already have a pair of 12LTA's. I am very excited! I was very excited about producing a unique baffle that looked you on The Edge program and would look good. I had an idea of how I would mount it by the LTA's magnet. Unfortunately, it was not to be. My daughter had changed the angle of my table saw blade enough that I wasn't getting 90 degree cuts. That led to poor joints, which led to a disaster, which I will post a picture of with my phone. I had made other mistakes, like not accounting for with diameter of my drill bit when I made my holes with a router and a homemade jig. I am just trying to learn the router. Oh well, I am learning as I go. So for now, I am going to keep it simple.
I think I will build the H-Frame out of MDF at this point. That way it won't be so terrible if I screw up. Poultrygeist, is 19 x 19 x 19 the outer dimensions of your H-Frame. I was planning to make the inner dimensions of mine 17 x 17 x 17. It occurred to me that I would use less material if I went with 16 x 16 x 16 which would also give me a tad more floor space. I would love to hear your opinion before I start cutting. I have also thought about trying to make 3/4" dados with the router to hold the Alpha baffles in place. However, I did purchase the mini Kreg tool awhile back with the idea of just using it to do plane but joints. Yeah, I should probably keep it simple. Maybe I can try to get more fancy at some later date, like when the weather turns warm again.
Thanks for all the help of all!
Sincerely,
Benjamin
BWebber, great project and you're bound to be impressed
19 inches are the outside dimensions.
If you go with 16 x 16 x 16 as the inside dimensions the 15 inch Alphas will be very close to the edge. Too close IMO.
Haven't had enough time to build my H-Frame yet. But, had just enough to test this out while scarfing down a sandwich. So far VERY thrilled!Thank you!
100hrs give or take
10 daysmore or less if you have the time. Or run em' round the clock. Even a notch filter will tame em' down
