Open Baffle Epiphany!
As I said earlier I'm sold on the Eminence ASD 1001 and they're staying put but I may try adding the Realistic tweeters to the rear of the baffle firing at an angle upwards. I've read that a second rear firing tweet should be wired out of phase so I'll see how that sounds.
BWebber, you shouldn't be able to hear the 12LTA and RS separately they should blend into one sound. I would try bi-amping. It works for me but I'm using an active only on the woofers ( driven by a TPA3116 ) with the Zenith/ASD powered by a EL84 SE with nothing in the signal path. If you go with a Yung plate amp one SD100 is more than enough to drive a pair of 15A's.
mkane, love your mono blocks. I've never tried a tube amp on the 15A but I do use a second tube pre plus a TPA3116 amp.
My Zenith/H-frame open baffles have to deal with this congested rack. The idea was to use as much of my gear as possible in a single system. I was able to do this and combine a multitude of sources through the use of analog and digital switch boxes. Sources include a Technics TT, SACD changer, Rotel player, PS1, tuner, Audio GD DAC with digital switching between an IMac, Chrome Cast Audio, Apple TV and Blu-ray. There are four amps used along with two tube preamps, one phono stage and one active crossover. Two OB woofers, one conventional sealed sub and two bucket subs are all used together.
Thanks for that. I was using a Mac 275 on the woofers and thought it sounded fine until I tried the monos. must be something wrong with the 275. No life at all. I've got a PP build in my future I will try on the woofers. To many irons in the fire at the moment. Still need to build some different baffles as an experiment and also some WAF approval. I have upgraded my notch filters with some different cap/inductors. The layout's a bit better though not there yet.
One more thing that really brought these speakers to life. I figured out how the hook up all the interconnects with no split signal. A revelation.DSC_0203.JPG
Edit; I'm putting together a DIY active crossover also. Waiting for parts. the DIY aspect of all this nonsense keeps me busy among other things. I missed all this when I had a job.
One more thing that really brought these speakers to life. I figured out how the hook up all the interconnects with no split signal. A revelation.View attachment 1008471
Thank you guys! Wow Poultygeist!!! Keep us posted on the diy active crossover. I just started reading about those last night.
This weekend I added a small shelf above the ASD 1001's and placed the RS 40-1310 super tweets on it firing to the rear. Now I'm hearing the 3D effect I was missing
with just the ASD 1001's. No issues running both pair of these high efficiency tweeters and the Zeniths from the same EL84 SE. I use a 1.5uF cap with each.
Haven't tried wiring the tweets out of phase as it sounds so incredibly good wired conventionally. I sure wish you guys could hear this system. :banana:
I've had my pair of Mark Audio Alpair 12ps delivered today. I am following the recommended break in recipe that Mark Audio has for their drivers. I know some don't believe in it and others go to extremes. Opinions be damned, I've decided to be safe and just do it the recommended way. This recipe calls for playing 100 hours of music that's not bass heavy (think easy listening station) at low volumes for 20 hours and gradually increasing to normal levels. So It looks like they'll be playing some of my favorite jazz and acoustic material for a while.
FIRST IMPRESSIONS:
They are gorgeous drivers. They look very delicate while at the same time have heft and weight that lets you know they are very solid and over built where they need to be. The spider is massive for a driver this size. You can really tell they work hard to make sure that each driver is built to the highest standard. They also come with a sweet rubber gasket to mount the driver to the baffle. I've been using a pair of alnico Philips drivers for a few months now and they are so light and flimsy compared to the beefy Alpairs. But they sound remarkable... So the competition is stiff.
Anyway, I have them sitting on a shelf hooked up to my DAC, laptop, and cheap little Nobsound TPA 3116 (Love this thing). Right off the bat, they were VERY harsh. Vocals were just nasty to the point of not really being able to make out the lyrics. My wife actually said "you paid how much for those?". I wasn't worried but still made that awkward laugh we make while we try to think of a way to justify our purchase to our spouse. ;)
We left the house to go to my son's soccer game and returned a few hours later.
I walked into my listening room and started the same song we heard when I first fired them up. Even after only having 3 hours of low volume on them they had smoothed out A LOT. voices weren't grating but now crystal clear and the highs were much more open. chalk it up to me wanting to hear it, but I think they really did clean up a lot. I raised the volume just a touch and really liked what I heard.
I'll be back to report after I can turn up the volume more and get the baffles built. I have a few ideas on my baffles that I want to try and I hope to get my H-Frames solidified with some bracing while these finish breaking in.
To summarize: So far so good.
Any update on the 12p's? I have a pair of 10p's and wondering if I should try them in OB's.
Short answer: They're great!!!!
Longer answer: I really, REALLY like them. They are very smooth and they play high enough for me to not need a tweeter. I may try and do the rear firing thing in the future but I want to play around with placement more and see how far that gets me. The imaging is pretty good right now and I suspect will get even better after I get placement dialed in and they get a few more hours on them (currently at about 110 hours or so) as multiple sources say they have a long way to go on the break in stage. They have a very full, open sound and voices sound quite real. They say the first 100 hours are crucial for break in on these drivers so I followed their recipe of low volume simple music for the first 100 hours while slowly stretching their legs as I approached 100 hours and beyond. I'm hoping things continue to get better in the imaging department, but as they are now, sound better than my vintage Philips AD8080s (another sleeper driver that can still be found for fairly cheap on the bay).
How do you have them set up? You using the 15a's too?
Yep, H Frame with 15a's baffle on top 18.5" wide x 24" high. Driver mounted 36.5 inches up from the floor (match my ear height in listening position).
Over the last week I've had a major system overhaul. I recapped my vintage mono block amps with Mundorf Supremes, added a brand new Luminous Audio Axiom 2 passive pre amp, and some new DIY interconnects made from Low capacitance Mogami 2497. So I think things really need some time to break in before I hear what the system is really capable of. It sounds quite good at the moment but sounds a bit compressed and the soundstage isn't as wide as I'd have hoped. But It could just be having all new parts needing some time to work out the kinks.
Somewhat finished my active. Case comes next along with a PS. And I got rid of that abomination of a notch filter. In it's place is a simple inductor and a Resistor. Who needs a super tweeter. DSC_0203 (1).JPG
Power supply up and running. Made 3 different notch filters. LDSC_0204.JPG istening continues. And Paul, all of you're posts are all very inspiring, thanks. No box speakers in this house.
So I will be rebuilding my open baffle speaker wooden fronts because it's time to use some beautiful local wood I recently saw at my mill. I will start this by saying that I a very happy with the sound I am getting with my current set-up, but as always I am looking for improvements and love to tinker. The wooden fronts I am rebuilding are 15" x 38" and will be made of local cherry and black walnut. For my full range I am using Wild Burro Betsy's and each side has 2 x 10" Goldwood GW-410D for woofers and are powered by a Yung SD200 200W. I will be installing Eminence APT-80 tweeters pointed at the ceiling. My questions are, could/would I benefit from replacing one of the 10" with 12"? Also what about the width of the wooden fronts? Would these benefit from maybe making them 16" or 17" wide? Wider?
Last question, my power amp is the Audiosource AMP 102 and has an A & B speaker option and both can be used at the same time. I plan on using Blue Jean Cables Canare 4S11 Star Quad Cable and using two conductors for the Betsy's and 2 for the Eminence, one from A and one from B. Is this the correct configuration for this set-up?
Thanks for your help!
24" would be a min. for decent bass reproduction. On the cheap Alpas 15a's one each side. When I get around to using some wood more pleasing to the eye my baffles are going to be wider & shorter. There now 24x40. I used cheap birch for the baffle plate that didn't take stain well at all.DSC_0007 (1).JPG
Ok so I will go as wide as possible. What about the 12" replacing the 10" or am I better sticking with the 10"? Also am I using the Star Quad Cable correctly?
