Open Baffle Epiphany!
Good to know... Wow, better than T90As huh? That's sayin' something. Those have quite the reputation!
I might be placing an order for the Alpair 12P this week--We'll see. Aren't these around 93db? Wouldn't that be ok for some of the lower powered stuff out there? Wattage isn't a problem here, I have a pair of Sargent Rayment 6l6 monos I'm rehabbing that put out about 15-20 watts (I'm guessing). They sound remarkable. Huge transformers and good, clean, effortless sound. We'll see what happens. I've heard nothing but good things about the Mark Audio Alpair drivers in open baffle.
I've said it before but, I just love how easy it is to swap drivers and try new things and get actual results that can make you look brilliant with your friends that come visit. I haven't had someone yet that hasn't had their mouth open and their eyebrows raise up when the music starts playing. I played my Pink Floyd "The Wall" for my Dad (he gave me the album plus all his other ones when I was a kid) and he just giggled when listening to it. Plus the feeling you get when you sit back, listen, and think "I built these" can't be beat. So glad for MJK and his wealth of knowledge being available to us.
Carry on sweet OB Epiphany thread... Carry on.
I made a nice mono system using a Zenith console that was going to the dump. I cut down the cabinet. Basically making it into a open baffle speaker. Then I refinished the cabinet, replaced the worn out speaker fabric.removed the cone tweeters and installed a Dayton compression driver and wave guide. Im also using a L Pad to fine tune the volume of the highs.
Right now I am useing the Zeniths speaker for a center channel with my HH Scott 299 tube amp that has a center channel pre out. The center channel is driven or amplified with the original Zenith tube amplifier that I restored awhile back.The left and right channels are Econowaved Large Advents..The the center channel adds so much to the sound quality compared to just the Advents. The center improves the sound stage, especially on old stereo recordings and seems to bring out the vocals much better then that of only the Advents. The Advents do a great job of bringing out the low frequencies
I set the zenith center speaker up as a temporary setup.But it sounds so good I'm going to have a hard time taking it down. Here's a couple pictures. Curt image.jpegbb
Right now I am useing the Zeniths speaker for a center channel with my HH Scott 299 tube amp that had a center channel pre out. The center channel is driven or amplified with the original Zenith tube amplifier that I restored awhile back.The left and right channels are Econowaved Large Advents..The the center channel adds so much to the sound quality compared to just the Advents. The center improves the sound stage, especially on old stereo recordings and seems to bring out the vocals much better then that of only the Advents. The Advents do a great job of bringing out the low frequencies
I set the zenith center speaker up as a temporary setup.But it sounds so good I'm going to have a hard time taking it down. Here's a couple pictures. Curt View attachment 995133bb
Very innovative! I bet the Zeniths add a great deal to the center channel. And since you've got two you can eventually try them in stereo OB's.
I came across these on CL. They look like little Zeniths. The add says they are 5 inchers but by my estimates they are smaller than that. Said to be from 1960 and overpriced, but there are 32 of them for sale. Thoughts?
Curtwheeler, very nice. Combining e-waves and open baffle with the center channel. Very cool .Have you tried opening the fire place to resonate the zeniths?
Katalyst. I didn't even think of opening the fire place. I'm willing to give it a try. The only reason I but the center speaker in front of the fire place is because it is equal distance between the left and right speakers. I was really pleasantly surprised with this setup, but I don't think I can get away leaving it permanent. Curt
Curtwheeler you owe it to yourself to try your Zeniths in stereo OB's. Not a day goes by that I don't marvel at mine.
Well that was my original plan. I was going to use them with a little Magnavox stereo single ended 6bq5 amp 8300. Then I got derailed with the Zenith cabinet mono speaker and then the HH Scott center channel experiment. Also spending a lot of time listening to my ADS 910's. No doubt I'll get around to trying the Zeniths in stereo OB's in the near future.
When you get around to it you're in for a real treat.
I drive my Zeniths with a single ended EL-84 ( 6bq5 ) Magnavox. Sounds just as good as my 2a3 SET.
I'm about to pull the trigger on a pair of Mark Audio Alpair 12s. I will also be making a new baffle for the top of my h frame, but will be trying out a few ideas I have to make a more solid and stable baffle to put the drivers in. I'll also be bracing my h frames. While touching the wood of the h frame, I can feel it vibrate the side of the wood which works its way up the baffle and make the metal brackets buzz with every kick drum hit. I do realize that it's a bit silly to be trying to make a flat baffle better, but I can't help but think the more solid the base and baffle are, the less likely I am to have any artifacts added. It works with box speakers, I don't see how it could hurt here either.
I love long weekends.
You don't have the Zeniths do you?
I don't. I keep looking for a pair with the alnico magnets. I had a pair of 49CZ(can't remember the last digits) They were smooth in the low mids, but obviously not the 852,703,etc. I passed those on a few months ago. There were NO highs whatsoever and the cone structure was very different from the good ones.
PoultrygeistI. That's good to know about the Magnovox amp. I have a pair of Dayton DT 250 P-8 compression drivers with the 5"X10"" waveguides I could use. I'm now using one with the Zenith speaker cabinet.The Dayton driver is really efficient so I used a L Pad to dial in the volume to match the Zenith. Also the Dayton plays down to around 1200 HZ. I used two 8uf caps to make a 16 uf cross over It sounds pretty good to me. There is no denying that the Zeniths have great mid range capabilities but I do think I'll miss the deep bass that the Advents provide. I'm not crazy about using a sub. Any opinions? Curt
