Open Baffle Epiphany!
Here's a more complicated filter. This is borderline perfect. Not very neat but I'll redo these with some assistance from someone who's got a few under his belt.AN10 Filter.jpg DSC_0001.JPG
You should try these terminal strips from Lowes. So much easier to work with.
I received a pair of Eminence ASD 1001 HF compression drivers from PE yesterday. Won't be using them piggy back as shown in the picture but as stand alone tweeters with small wave guides. I'll see how they compare to the Realistics when paired with the Zeniths.
Those ADS 1001 compression drivers are cool. I used them with my Beta 12LTAs and a few other drivers. sounded good, but then again, all the stuff up that high is just a bit of shimmer.
I will be very interested to see how they compare. I planned to get those and try them both forward facing and rear facing.
Same here. BTW, Eminence make coax drivers in 8-10-12 inch formats that would fit these but I don't think the specs would work with Open Baffles.
The 12" driver looks like a 'maybe'...?:dunno:
I've always thought that closed back tweets should be rear firing but I don't know about these. Godzilla has them firing to the front.
I just used them with a 1uf cap (and a 1.3 I think). forward facing. haven't even thought about firing them bacwards. Maybe they'd be less harsh? I'll hook em up this weekend and see.
jelly, I believe the ASD 1001 horn tweets can be piggy back mounted on the Beta 12LTA and firing through it's throat coaxially as in the picture above which shows another Eminence speaker. Emerald Physic designs did this with their OB's which used the 12LTA.
When I first started with OB's I would add a tweeter shelf so I could try out different tweeters. Since these Realistic tweeters were in their pods they sounded better firing to the rear.
I just used them with a 1uf cap (and a 1.3 I think). forward facing. haven't even thought about firing them backwards. Maybe they'd be less harsh? I'll hook em up this weekend and see.
Behind the main speakers firing up often works even better.
I will check today. The rear of the 12LTA has a hole that could house the asd 1001 but it doesn't look like it's threaded to accept it. I would love to try this too. I'll look closer today. I need to do yard work before it gets too hot.
I'll put this out here real quick instead of starting a new thread.
The auction site has a whole mess of old soviet era speakers. Klangfilm/Lomo Kinap speakers from the (consumer grade??) 4a series to what appears to be their higher end cinema drivers. They all appear to be very well made drivers and can handle up to 14-16khz. Does anyone have experience with these?
I've found some videos on YouTube that show them playing in free air and in various boxes. They even sound pretty nice through my laptop speakers. Apparently they also made cinema tube amps that go for a whole lot of money.
My open baffle in test fase, with MDF construction: vintage 12" RFT L3060PB 99 dB german alnico drivers plus BEAG HT101-16 101 dB hungarian vintage tweeter, with small 3,5 W CEX 6n6p, 6n1p / EZ81 tube amp. Really not bad set.
I think, the Lomos are overrated and overpriced, the german big fullranges (from Eastern side, too) were much more better. For example I use the RFT L3060, I bought the pair for 60 Euros in Hungary - they are good till 12500 Hz, deep basses, very smooth midrange. It was used at first in cinema systems, then in PA, and at last lifepart in guitarcombos, too. Huge alnico magnet, iron corpus.
My problem with the Lomos is, that I never heard a similar pair, the quality check must be very bad in USSR.
5572d7624fca99a4c67f792f28df
Thanks Baowah! I saw a few here and there that ranged in price from 100 to over 500! Glad to know that before I pulled the trigger. I'll look elsewhere.
Thanks for the recommendation on the RFTs. I'll take a look. :)
when you can buy a pair of tannoy hpd315 for 700 Eur, never buy a Lomo for 500 :)
A I see, the eastrern loudspeakers are very overpriced on ebay, better to find somewhere on lokal "craiglist", can be much more cheaper.
between commies, de hungarian BEAG HX-301 can be interesting too, but it is good only to 7000 Hz, it needs a tweeter. But it is huge, robust 97 dB driver.
