I like the sound overall better than anything I have ever had before. I would describe the sound as having depth and sounding quite real. David, I will try to lay out my current hook up. All sources are connected to my Bottlehead Foreplay II pre-amp. For my Turntable, I go to a Sansui receiver and pre-out of that to the Bottlehead pre. I have y-connectors on the output of the Bottlehead. From there, one lead goes to my SET tube monoblocks that power the Eminence Beta 12 LTA. One per side, of course. The other lead (on each side) go to a Behringer CX2310. From the Behringer to a slightly modified old Sonic Impact amp that powers the Eminence 15 Alphas. FWIW I will mention a few observations. Feel free (anyone to comment).
I listened to some Voigt Pipes based on the Fostex 166 for a few years. I used the $28 Sonic Impact for awhile after my kid destroyed my H.H. Scott. The Sonic Impact was very dynamic and clean, but had too much upper mid-range for my tastes. I did the most basic mod, which was to replace the caps that the geeks on the forums had determined were limiting the bass in the original design. That turned out to be very worthwhile, and I did get a lot more (deeper) bass than before. Next, I built some Folded Horns (the Bigger Is Better BIB) based on the Fostex 208 sigma. I got a Cary Audio Rocket 88 and listened to the Fostex 208/Cary combination for many years. The bass on the $2500 Cary was not as tight and tuneful as the modded Sonic Impact, but the midrange was way more to my liking.
I was lucky enough to make friends with the late Paul Weitzel. He designed and produced high end amplifiers for a living, but had never done a flea powered SET amp before. Over a period of 4 years, I would travel the one and a half hours to his shop. He would do a little bit of work on one of the monoblocks from what he thought would work in his head. He would send me home with some parts, and I would copy his work into the other monoblock. Shortly before he died of undiagnosed pancreatic cancer he sent me home to power them up. I was supposed to bring them back after a few weeks and then let him know how I would like to change the sound. As it turned out, I would never go back before attending his funeral.
The amps are based on the 45 tube, so I probably have two watts at most. It is enough (barely) in my room. The interesting point that I wanted to make with all this is the following. Now that I have the SET amps, I would say that I almost consider them to be mandatory to really make the 166 pipes or the 208 BIB's sing. I have not done much A/B testing, but the one time I did with these OB's, it seemed the OB's liked both amps. In other words more of a which flavor do you prefer question. One the other hand, as good as the Cary was, I thought the SET amps blew it away with the other two speakers. The SET amps solved the shoutiness problem better than anything else I had done.
Here comes the next thing I discovered that came as a big surprise. I started out powering the Alpha's with the Cary. I attenuated them as much as I could with the Berhinger. One day I decided to try having the Sonic Impact doing bass duties. And, I liked it better! No offense to the Cary, and I would much prefer the Cary on the LTA's vs the Sonic Impact on the LTA's. But I found that I actually preferred the $28 SI playing the Alpha's to the $2500 Cary doing bass duties on the Alpha's.
The ASD 1001 tweeters are also connected in parallel with the 12" LTA's, powered by the flea watt SET's. The + leg of the 1001 has a 1 uF and a 0.33 uF. The caps are in parallel and in series with the tweeter. Thus, a capacitance of 1.33 uF for each side. Someone on some forum had raved about this dirt cheap caps made by Vishay, so I ordered enough to try .47 though 1.5 uF. My only complaint is that the leads are just tiny stubs. I almost forgot, that between the SET amps and the speakers, I have a pair of autoformers. The autoformers allow me to double, triple or quadruple the impedance that the amps see. I think my SET's like a little higher impedance. It makes everything tighten up. However, it can get a little "mean" to the ears of you go up too much.
The other day I turned the Berhinger on while having the Sonic Impact (bass amp) off. I noticed a change in the sound. Like a small dB reduction. I also discovered that I could hear an element of the upper bass when I had the alpha's off, that I was missing when I had them on. The bass I have with just the LTA's is a little cleaner sounding than with the whole thing. This does not mean that I don't want the Alpha's playing! Just an observation that verifies what some have said, that there is something special about connecting an amp directly to one single full range driver. It is also true, that everything is a trade off. For now, I am very pleased to have the Alpha's in the H-Frames. Although at this moment, I am running them set to 60 to 80 Htz, and have both the input and output volume controls as far counter clockwise as they will go. That does not shut them off. I think I want to try adding those 5 gallon bucket subs to the system someday and see where that leads me. It is not that I think I need more bass, but the hope that I can get better bass. And, I am not saying that I am unhappy with the bass that I have. I guess it is just that audiophilia thing.
I do like the speakers positioned out from the back wall. But, I don't like people tripping over the chords.
I want to that PG and all again for inspiring me to build these things!
