Look for vintage wide band speakers pulled from open backed consoles and tube organ speakers. 12" wide banders such as Zenith, Magnavox, Conn, Hammond etc can be found on eBay for reasonable prices
Hello Poultrygeist. For many I have tried with plywood and MDF and leather on open baffles. But the best material for open baffle is polystyrene with real leather. It is uncoloured and soft sound. Very better and relax sound.Opposite plywood and MDF are colour and annoying sound especially at high levels. And polystyrene is very cheap. About 5€ the sheet. And if you join with glue real leather with polystyrene you will take the best natural sound. With the woods finally you hear the woods. Not the drivers. And I don't like this.I've had good luck with both plywood and MDF in 3/4" thickness. A full sheet of either would be 4 ft X 8 ft which stores like Lowes or HD will cut down for you if you buy from there.
I can buy a full sheet of MDF for around $25 but the same size sheet of good plywood would cost at least twice as much. I haven't heard any resonance with either but I never play at extreme levels.
Small group acoustic jazz does not require high volumes which could excite the baffles so complex bracing and exotic sandwiched thick layers aren't necessary in my case.
Plywood advantages: easy to finish, looks good, and no toxic dust
Plywood disadvantages: costly, subject to voids in the plies, less dense
MDF advantages: low cost, more dense, no voids
MDF disadvantages: toxic dust requires a mask when cutting, difficult to finish or paint ( it's why I wall paper mine )
But and only polystyrene is very better than wood.Hello Poultrygeist. For many I have tried with plywood and MDF and leather on open baffles. But the best material for open baffle is polystyrene with real leather. It is uncoloured and soft sound. Very better and relax sound.Opposite plywood and MDF are colour and annoying sound especially at high levels. And polystyrene is very cheap. About 5€ the sheet. And if you join with glue real leather with polystyrene you will take the best natural sound. With the woods finally you hear the woods. Not the drivers. And I don't like this.
Yes they are real leather. The material for sound.Are they leather???
Yes sometimes I play loud and i want uncoloured sound to all volumes. This is the difficult. I m pianist and i want the music live! But with the right materials and the right thickness of materials of the baffle you can succeed this.I hear wood with OB's but it's from the double bass violin. If you hear resonance then you're playing them too loud or your baffle/mounting system is at fault.
Yes PG you have right for the cork. I forgot to tell for this. Also I would like to hear your opinion for this... I have asked to Pureaudioproject for the OB a15 neo drivers instead Eminence Alpha15a . And he answered me this:Cork is also a good material to use on baffles. The backs of these OB's consist of several Ikea placemats glued to 3/4" plywood.
Hello Goggle you need two big leathers thick and hard and two wood cycles for the drivers. Or if you have baffles from wood or polystyrene or cork , you can glue the leather to the baffles. The leather is the best acoustically material because is flat throughout the acoustic spectrum without colourations and very very natural sound. Now I plan to glue all leather to my new baffles from polystyrene.Miron, I find this fascinating, can you share more information about how your baffles are made?
"Hi Miron and thank you for your mail,
The OB-A15NEO is way more musical and overall uplift over the Alpha15. Qts and other features are matched for best control and avoidance of one note bass phenomena.
Bass is deeper than Alpha but very musical and life ! Just like the instruments sound.
We normally provide a set of components for voicing and the price of Leonidas with these will be 690.-US$ in the US or 690.-EUR in the EU (EU price is incl. VAT)
Look forward to hear from you,
Regards,
Ze'ev
Please PG ,I want your opinion for these drivers because these are the "update" instead Eminence Alpha15a especially for open baffles. I appreciate your opinion and all here at the AK ,you can tell your opinions for the OB A15 neo...
Thank you PG for these options that you gave me. Is it ok to have active crossover with one pair of these woofers with the Zeniths and bi amp (845 single ended for zenith and allo d class amp for pair of woofers)??Another great woofer which Lowther America used in their OB's. The 12" Tone Tubby has hemp cones and alnico motors. I read that it's Carlos Santana's favorite.
And Tone tubby does not write qts and sensitivity...
http://aespeakers.com/shop/ bought a pair of DP15's. There big and very heavy. Would have gone with ToneTubbys but they wouldn't have been a drop in @ 12".I think that Tone tubby is preferred because is 12inch and faster than 15inch. But I have a question. Perhaps another pair zeniths with the active crossover can to add to the speaker project? Or Zeniths are only midrange drivers?Another great woofer which Lowther America used in their OB's. The 12" Tone Tubby has hemp cones and alnico motors. I read that it's Carlos Santana's favorite.
