Poultrygeist
Lunatic Member
Nice. The OB world was saddened to see Hawthorne stop production. Hope Daryl is enjoying his retirement.
Hello Goggle, the foam is 3cm. Now I have not wood with the polystyrene baffle. The driver is screwed on the polystyrene. And I plan to glue the leather with the polystyrene.Miron, can you share more details about how your leather OB’s are made? How thick is the foam? How big are the wood circles that support the drivers? Maybe you could show a picture from the back side of your big leather OB’s.
This idea of leather as a surface treatment fascinates me.
Thank you Miron.
Hello Poultry! What tweeters have you to your baffle with Zeniths?? Have you only a simple cap for tweeters??I've enjoyed a variety of tweeters over the years but the finest OB tweeter I've experienced so far is the Planar dipole B&G Neo 3 PDRw-2. B&G stands for Bohlender Graebener which went out of business for awhile when the owner passed away. I bought the two versions of the Neo 3 from PE shortly before they ceased production. Happy to report that B&G's are back in production and PE is carrying them again. They come with a back cover that makes them appropriate for box speakers. The cover is lightly glued on and should be removed to get the benefit of OB rear radiation. In the picture you can see how a blade is used to gently pry off the back cover. The round mount is extra and not necessary but it does allows for easy use with box speakers and OB's.
If I put the same tweeters to my baffle without woofer is it good idea??
Thank you!![/QUOTE
With the Zeniths I use the Eminence ASD 1001 compression tweeters with wave guides paired with rear firing Realistic ( Radio Shack ) pod tweeters. Both tweeters use a 1.5uF cap on their + terminals and are driven from the same amp that powers the Zeniths. The Zeniths and tweeters cover the mids and highs but I like the Alpha woofers for the LF.
Hey P, are you still using that horn? I use them in a pair of bookshelves and really like them.
Thank you for your reply. I See that Eminence has a plastic at front that it has not it normally . What is this??
Yes I understand. Of course Is this necessary for Eminence??You can see the threaded end on this ASD 1001 tweeter that accepts the waveguide.
Thank you for your rich informations Poultry!!!Zilla a friend at diyaudio uses the Eminence ASD 1001 in his OB's. Here's his blog which I'm sure I've already shared but this thread is too long to find or reference it.
https://speakerprojects.wordpress.com/2016/08/29/eminence-beta-12lta-on-open-baffle/
