Open Baffle Epiphany!
Cork can help deaden the baffle. If you play OB's at extreme levels the baffles will resonate. I don't care for extremely loud music so it's never been an issue. So this cork ended up being more cosmetic than anything else. They're inexpensive placemats from Ikea that just happened to fit.
Ok I've been reading a few days and still have only got to page 55 of this thread. I've been planning to build OB's a few months and have bought the following drivers..... My plans keep changing:
Tweeters
Skar Audio VX1-ST Bullet (108db, 4 ohm) - Intended for the front
Dayton AMTPOD-4 (90db, 4 ohm) - Maybe on the back?
No name ribbons - (98db 8ohm) - Maybe on the back?
Fullrange
Dayton PS220-8
Bass
Eminence Alpha-15A
Now I'm currently wondering why I don't just purchase some down firing 15" subs like these and simply glue the baffle with fullrange and tweeters attached as opposed to the Eminence Alpha-15A's? Simpler and easier I'm sure with better power handling. Wouldn't most of the benefits of open baffle be in the full range drivers?
I rarely give my system too much power though every now and again ( once or twice a year) when my wife is out I like to crank it for a half hour or so.
What are the pro's and cons of this approach?
I can't help but feel that this would solve the requirement for more bass while being less than the cost of a single Acoustic Elegance Dipole 15 and neatly bypasses some of the difficulty with EQ etc. Seems similar in concept to the designs with a downfiring sub with the simple difference that this one is boxed. Likewise it has to be simpler to bold a plank of wood to a sub than anything else....
Thanks in advance guys. I've some gear I listed for sale (locally) to raise funds for the sub should it be a good idea. Will put some bolts straight through the sub to secure + use liquid nails :)
Yes, I accept that what bass is produced in an open baffle is more realistic. It's just that it doesn't go that low so either way it seems a trade off is made.
Ahhh, those subs are 120vac only. Nothing else suitable in the price range. Seems I'll be using the Eminence Alpha-15A's after all for the initial build.
I'll begin saving for a pair of Acoustic Elegance Dipole 15 drivers and start tinkering with using a MiniDSP between my Linear Tube Audio MicroZOTL 3 pre and darTZeel NHB-108B copy power amp. Should do the trick I think.
Mmmm, currently wondering whether vintage Altec Lansing 803B drivers would work better than the Eminence Alpha-15A's. Not cheap though a lovely looking speaker and Altec Lansing have a great reputation.
University speakers are also quite stunning. University Diffusicone speakers are meant to be very nice in an open baffle though I don't really want to replace the Dayton PS220-8 in the design. I love the sound of those drivers.
I appreciate the fact that the Eminence Alpha is inexpensive and doesn't require tweaks. It's like it was designed strictly for open baffles.
Caintuck Audio used the 10" Alpha powered by a plate amp while the Betsy runs full range powered by the main amp. I believe Randy is selling them now through the
Decware site.
http://www.caintuckaudio.com/Betsy_Buck.html
I know, though do you think the Altec Lansing 803B would be better? I'm curious. I read earlier in this thread (somewhere around page 67or so) Magnavox drivers dug deeper with more bass than the Alpha-15A. Has me considering vintage drivers.
Some, like the Altec Lansing or University drivers are functional works of art.
The 12 inch Magnavox drivers pulled from tube consoles are similar to my 12 inch Zeniths. They work great as full range mains and you can add a pair of high Qts ( 1.0 and above ) woofers for a nice two way set up. With large baffles they may have enough bass to go it alone.
Ah.... Got ya.... I'd better stick with the proven formula then..... Dayton PS220-8 + Eminence Alpha-15A.... Will have a pair of super tweeters too.
Thank you so much Poultrygeist.
It's taking me ages to read through this thread though picking up all sorts of useful info. Even tidbits like a "circle cutting jig" for my jigsaw.
Getting close to actually assembling now. Will be interesting to compare with my Oatlon W2-1000F and Aurum Cantus F620 speakers :)
I thought I'd add the DIY Manzanita Ultra to this conversation. The speakers have 2'-x-4' MDF baffles and passive crossovers. The drivers are GRS-15PF-8 15" woofers and Vifa TC9FD18-08 3.5" tweeters. They were designed by John Busch, who has continued to tweak the design over the last decade. The current design is in this DIYaudio post. Mine are pretty much stock, except for the addition of a woofer trap and a small bypass cap in parallel with C1.
Has anyone tried bass LOADING the front of the bass driver ALA. Emerald Physics ? That looks pretty nice and is supposed to improve Bass.
Specifically talking about trying this on / in an H-Frame
They look great. How do they sound?
The Manzanita Ultras sound very full and surprisingly warm. The budget full-range driver that serves as a tweeter might not deliver the absolute top end of the spectrum, but it has a lot of presence in the midrange. Great soundstage. Unbelievable bass that extends down to the low 30s. A really enjoyable speaker and a fun project for a first DIY build.
