Open Baffle Epiphany!
I'm sure there is information somewhere in this thread about ob baffle size (I'm only through page 25). I've been reading a lot about it from other places on the internet too, but have been getting a lot of conflicting information. I get the need for space behind the speakers and it seems like 3 feet is the minimum recommended, and I found a few programs that people have made to configure room size and speaker to baffle size, but I can't seem to find a definite answer. Also looking at all the commercially available ob's it seems pretty arbitrary to me. Any thoughts on this would be greatly appreciated. And I'm sorry if it's already been posted here and I just haven't gotten to it yet.
Decided to hedge my bets. Have bought a nice pair of Magnavox 15" Console drivers. Will try those as well as the Eminence drivers.
There's lots of differing opinions on flat baffle size. From my experience once you add high Qts woofers to full range mains in bi-amped configuration baffle size becomes less important. The best sounding OB speakers I've heard were baffle-less which were real head scratchers. But with double 15 inch woofers on flat baffles I'm partial to 4' x 20".
Thanks, this pretty much sums up what I had been thinking. And I saw the video you posted of those baffle-less speakers, the video and sound quality isn't very good, but I'd be really curious to hear them in person.
The video and sound from the phone is not good. But I was there and the aural experience was jaw dropping.
I front mount as it's more secure due to better weight distribution. Also easier to place a gasket between the frame lip and baffle.
Well I threw together the EV speakers into a simple baffle and have been playing around with placement and so far my ears and brain are toast from trying moving them around and trying to listen overly critically. They are really temperamental about placement. So far I can't tell if I like them any better than my boxes, but they certainly aren't any worse just different. I can see how this could become really obsessive.
Ok, grabbed a pair of 10" Zenith 49CZ for my OB's. The 15" ones have become near unobtainium and my OB's will be 3 way anyway just using the Magnavox for added bass and a pair of super tweeters.
Wonder if I should run the Zenith's full range with a little overlap in the bass with the Magnavox. I've found I actually prefer a bit of a bass hump recently so it will probably be right for me.
I expect this will be world's better than the Dayton PS220-8 + Eminence Alpha-15A combo based on what I've read regarding the Zenith and Magnavox drivers. I daresay the old Alnico drivers will sound superior all round ;)
You guys are a bad influence on me :p
jelly_bean >
Hi! having warmed up a sound of loudspeakers (training) takes rather long time. After that loudspeakers get the voice. Old loudspeakers lose the indicators from long storage. Lose also impregnation of the diffuser. Practice showed that very good restoring impregnation is propolis. Stradivari used this circumstance too. I used propolis for impregnation of loudspeakers. The sound was more articulated. Propolis infuses on alcohol, for impregnation only transparent tincture is used.
Do you mean I need to paint the speaker cone with something called propolis?
The Zeniths sound wonderful full range and unlike so many modern drivers they have no warts to treat.
Many of the early consoles had no backs so it's not surprising their drivers work well in OB's. I am in the process of mounting some 8" Zenith alnico's over the H-frames. These Zeniths were in the same console with the 12" 49CZ802's and their name and ID's were intentionally blacked out at the factory. I had kinda forgotten about them until I realized that except for their darker cone they look like larger versions of the Coral Holey Baskets.
Well, this is them. :)
I look forward to receiving and setting these up full range. The Maggie's will be set up to supplement bass with an 8.2mH inductor. I'll have a high efficiency bullet tweeter as a super tweeter with 3.3uf caps. Should be a very nice 3 way ;)
The cones and motors look identical to the 12" 49CZ802.
I painted my faded gaskets with some flat black latex.
Those cones look perfect and need nothing.
As good as they sounded I couldn't keep the Coral Holey Baskets in open baffles as I don't have the space. They also shared the same H-frames as the Zeniths. They've now been moved to the Frugal Horn cabinets and offer a significant upgrade to the Fostex FE126En.
Great to know. I may spray the back metal bits with clear to prevent corrosion / rust. Brisbane tends to get humid and I don't want something irreplaceable rusting :)
The A is better but the others are still very good. I googled Goldwood paper cone tweeter and found the GT-25 which is 90 dbs. It would not be good match for the Zeniths which I estimate are in the high 90's. You need super tweeters that are 100+ dbs otherwise you won't be able to hear them.
Makes me happy I ordered Skar Audio VX1-ST bullet tweeters. 108db sensitive. ;)
I read a bit earlier that facing forward the tweeters might sound harsh. I'm crossing over with a 3.3uf cap.... Do you think this would be an issue? Should I mount it on the back angled up as others have? I mean they're a cool looking driver so a shame not to see them though in the end its the sound that matters.
Seeing as they'll use Skar Audio, Zenith and Magnavox drivers I'm thinking I'll call them Skarzenvox though I guess I could reverse it and call them Magzenskar?
I've been talking to @Nixxuz who pointed me to some research that indicates damping the front baffle would decrease bass response. I've been considering using Dynamat Extreme sandwiched between wood fronts and an MDF back on my OB's. I figured it would be beneficial at higher volume. What is everyones experience with vibration damping OB's? Does it hurt bass response at all?
Just thought I'd ask as I prefer tried and tested to theory. I can't help but think the 18mm thick composite wood front is a bit thin. Was looking at screwing the MDF back on with some silicone glue underneath.
The compression horn tweeters by themselves were too forward prominent till I balanced them with rear firing Realistic super tweeters.
Mmmm, seems I may need a second pair of Skar Audio VX1-ST so one can be mounted facing the rear.
Theoretically mounting facing back and angled up would do away with this would it not? Bounce off the rear wall and up to the ceiling..... Maybe if I can find a way to have a hinged mount then I can adjust the angle until it works best for each baffle.
