Open Baffle Epiphany!
I know lots of folks are pouncing on the Zeniths when they come up on eBay but you risk buying a "pig in a poke". You're better off looking for a Zenith console and buying it. That way you can have a better idea of how they were treated. If anyone is dissatisfied with the sound of the Zeniths my bet is they got a bad pair.
So.... it's safe to say that the Fostex and GRS are "out of the closet," but that the Radio Shacks are still "in the closet"?
Yes the 40-1286C 8" FR drivers from Radio Shack are keepers. Surprisingly nice sound. One place I read said their Qts is 1.16 which if true is perfect for OB.
I've considered trying these out before... but never have. This might be a good excuse now for me to try them.
I currently use some vintage 8 inch Heppner speakers for my small OBs.
I've had them for several years hidden away in my audio closet. Won them on ebay for around $20 but remember when all the Radio Shacks sold them. Like many of the Realistic speakers it's possible they were made by Foster/Fostex in Japan.
I've added a couple of bucket subwoofers to the OB Realistics so my closet HT is now a 2.2. Bass is accurate, plentiful and not the least bit boomy. Who would have thought you can turn a closet into a fine sounding system?
Ladies and Gents, introooduuuuuucing.....
................................................................................The SOUND CLOSET!
Our newest WAF design you can't live without'
...but your wife can live with!
What the hell more can you ask for?!!
The mighty "Wall of Sound" gives way to the "Closet of Sound".
hey Poultry, that looks a lot like a wider version of my 'computer space' including the doors.
How far are those speakers from the wall? Those racks can't be more than 24".
BTW, paint that pink wall dark blue, or green or anything dark. It will make the viewing so much better.
They're 16.5 inches from the wall and I wouldn't have thought they would sound this good. Yeah the pink is ugly but it's a junk closet in a spare bedroom. Thankfully you can't see the pink while viewing/listening at night with the closet light off.
If I had another 8" Realistic driver I'd use it as a center. Tried a Fostex in the center but it didn't blend with the others.
This is the only view of the Closet OB's that the wife appreciates.
Do the Realistic 40-1286Cs sound better than the GRS 8" drivers and the BOFU 8" drivers sold by Parts Express? I've got both pairs stored in a closet (yeah...more closeted speakers!) because they just don't sound all that great.
Interesting, a chap on the Open Baffle Only facebook page posted about his OB's using a pair of Ciare CH250 drivers. I find these rather interesting as the pricing per driver is really quite low. Tempts me to build another pair though I've really neither the space, time not inclination to do another pair.... I really shouldn't.....
http://loudspeakerfreaks.com/Product.asp?part=CH250&Product_ID=13861
The facebook post: https://www.facebook.com/groups/133540410120537?view=permalink&id=1461264830681415
Specs are decent for OB and low powered tube amp use I think:
Key Features
Double cone, membrane and cellulose suspension
General Specifications
Musical power (W): 150
Nominal power AES (W) 50
Nominal diameter ('' / mm) 10 '' - 250mm
Nominal impedance (Ω) 4
Voice coil diameter (mm): 32
Sensitivity 1W / 1m (dB) 96
Spare part code
Thiele Small Parameters
Re 3.4
fs 65
Qms 12.8
Qes 1.53
Qts 1.36
MMS 18.6
cMS 0.32
D 208
Vas 52
BxL 4.1
Linear Mathematical Xmax 0.5
n 0.89
Le (1kHz) 0.24
materials
Basket Type Steel
Magnet Type
Cone Material
Suspension Material Paper
Spider Material
Former material
Winding material
Connector type
Cone shape
Gap height 6
Dimension and weight
Overall diameter 265
Total depth 95.5
Flange thickness 9
Front mount baffle cutout diameter 238
No. of mounting holes 8
Mounting holes diameter (mm) 6
Bolt circle diameter 253
Gross weight 1,35
On another note I recently changed the 3.3uF KZK White Line bypassed with 0.033uF Miflex KPCU on my tweeters to 5uF Cornell Dubilier SFA44T5J219B bypassed with 0.47uF Duelund JAM.
While I can't attribute the positive change in sound to cap choice alone as the values have changed (dropping my crossover point to around 2400Hz) I find I've a little more sparkle and critical detail, less vagueness with female voices and a airier and more open sounding presentation. I believe the vagueness I was getting was due to a gap in covered frequencies however the airier presentation and added sparkle is likely down to better cap choice. Just a guess though.
The nice thing about the Cornell Dubilier caps is that they're really rather cheap, being made for automotive use and all.
Mmm, now that I've lowered the crossover point for the tweeters I can run them at full without needing the L pads. Sounds great. On the other hand now I find myself needing more deep bass.
I'm afraid I'm going to have to bi-amp. I've an S.M.S.L. SA98E ordered for it. Should do the trick. Going to have to rewire them internally.... I may even install the Eminence Alpha-15A's in place of the Magnavox Alnico woofers.
It was only clear how much the bass is lacking once I got my tweeters working correctly. Amazing how much of the magic of music is hidden in the treble though the same can be said for bass as well.
Bi-amping open baffles has always been a given.
I kind of didn't think it was necessary.... Not until I got my tweeters working correctly.
I think it may well lead to me installing the Eminence Alpha-15A in place of the Magnavox woofers. I love how my system just keeps getting better and better now. :)
If you bi-amp and use the Alpha 15a they won't need that much power. Any old amp of about 50 watts should be sufficient. I once used an AV receiver in stereo mode to drive the Alphas. An expensive amp would be wasted on the Alpha woofers.
I've an SMSL SA98E on the way for it. I'll remove the volume knob to avoid accidental adjustments :)
