Some of the guys on the DIY Forum suggest a smaller FR driver might work better with dual Alpha 15s. Less beaming and better uniform polar response are the reasons given. 4 inch drivers are being recommended. Any thoughts on this?
cubdog
Have the guys at DIY tried dual Alphas with small FR's vs larger FR drivers or are they speculating? This is the reason I put more stock in someone's opinion if they can show me their build and tell me how it sounds.
The issue of a smaller main driver raises the question of where the crossover is going to fall. The higher it gets, the more audible it's going to be. How are you going to deal with it? How well do the drivers blend together?
With my way of the multiple 8's, I just don't really need any cross so I sidestep the whole issue.
Remember the voice range. The 300 to 3K thing. That's the area to know the ear can detect our electronic tomfoolery the quickest.
EV3
cubdog,
You could have your OB's custom built with a small interchangeable baffle to test different size FR's ala MJK's design. This way you could try different sizes and choose what you like best. It would also allow an easy upgrade for more expensive or new drivers introduced in the future.
The bottom part containing the Alphas would not be changed. Take the dimensions to any cabinet shop and they'll have no problem building them with your wood.
EV3
I have know way of knowing exactly what their personal experience is. I made it clear that my preference for an 8 in driver was due to recommendations from those I trust. I also made it clear I'm a novice and that any and all recommendations are welcomed. It's a learning process for me and one that will take time. The more information I can gather and process will hopefully save me from a failed build.
The more people you ask the more different recommendations you will get. At some point there will be too many inputs to see a clear path forward. Since you do not seem to want to do the design work yourself maybe it would be best to pick an existing design and replicate it without any attempts at making inprovements. Start simple, you will learn a lot more by doing then by discussing on forums.
Ok, this is on page 33, so forgive me if this has already been covered. I have a pair of Morel Professional 12" coaxial drivers that are used for stages, studios and car audio. I was thinking of trying an OB setup just to see what they can do.
How do I determine the size of the baffle? Is there a formula to determine height and width? Is there a "cutoff" like with box speakers? Are there concerns with high frequency diffraction?
Those Morel's should be fun to play with OB. They probably are a lower Q design, so provided they have the xmax, you'll likely be wanting to use some form of EQ to bring up the bass.
The wrap around distance is going to determine where a 6db roll off is going to begin. Again, same on the eq need. Between the two, you're going to quickly run out of ability to drive it hard enough (power) and the driver have the ability to move far enough. Limiting how low you try to go plus how loud you listen are your way to deal with that.
As far as height, I'd suggest getting the tweeter up towards ear level while seated. So 30 to 38" to the center of the driver in this case. Positioning the driver lower will, depending on distance, add some floor reinforcement at some frequency. That may be desirable or not depending on where it falls and if you can listen to the perspective of being on the balcony looking down at the stage.
Using some heavy cardboard and playing might be a good way to start. Should be a lot of fun to play with and hear as an OB driver. Don't forget you can augment the lowest end with some other seperate sub if you have one around.
EV3
