Some photos ofView attachment 727587 View attachment 727588 my Isophon open baffles.
I allowed an anticipated small roon small footprint to drive my build.
I drove them with a Marantz 2325 and the sound was surprising good.
However there was a predictable absence of base response with the tone controls flat but I was able to compensate using the tone controls... the base needed to go way up and the kids a goodly way also.
While you would loose the "point source" benefits, I'd be very tempted to remove the tweets from their brackets, invert your baffles to get some floor effects for the bass, and mount the tweets (at ear level) in free air above the baffles ... Just to see how much free bass you could achieve without EQ.
minidsp has its own software; you have to buy it from them. the minidsp software can accept room corrections from REW.
i used a rane analog x-over 1st. problem is my set up is 2-way and i wanted to cross at 100hz and rane was 3 way and was hard to use it for a 2-way rig. had to cross higher, 150 or so, i forget just where. minidsp didn't sound worse; as i recall, it sounded better.
Some photos of my Isophon open baffles.
Glad you mentioned the software. I didn't realize that it was a separate item. Looks like 2 x 4 advanced is the way to go?
