Did it come as a mono amp with crossover, or is it your own creation?
Thanks!
Hey Poultry,
I just picked up a pair of WHARFEDALE 12/FS/AL drivers.
What would you suggest as a baffle design?
Thanks.
Recessed works and probably looks better. Gives a more finished look.
Couldn't find it on eBay- can you point me in the direction?No I could never come up with something like this. You can buy them on eBay and then you build your own case and add a power supply. This is what the naked amp looks like. No bigger than a pack of cigarettes.
If you search "TPA3116 subwoofer" and scan through the listings you'll spot this board with the two potentiometers
not using an f mod using active so this goes upstream of the full range amp or where you show it. All my parts are here except for the AN speakers.The Fmods ( or any active crossover ) would go upstream of the amp:
Source > preamp > Y cables > full range amp > full range speakers
Y cables > Fmods > woofer amp > woofers
If you don't have a preamp you can come off the source with Y cables and feed both amps. The Fmods would then go on the input of the woofer amp.
A good way I've heard it said to set it is to start with the bass turned all the way down. Then slowly bring it up until you hear it.....then back it off just a tiny bitThat'll get you going anyway until you listen to some familiar music and can maybe fine tune from there.
Bucket subs!. You use a Home Depot or Ace hardware bucket along with the Peerless
