Poultrygeist
Lunatic Member
These are hybrid OB's over H-frames and they run full range as well.
OTOH a passive crossover tries to do the impossible and that is to perfectly stitch two different speakers together.
Impossible? Maybe what you should say is that you have not been able to implement a crossover that you like with your equipment. A passive crossover can transition a signal between two drivers seamlessly if done correctly.
I see that you addressed the BP gain by "separating" the xo points by 300 hz. to eliminate the "hump".Are those full range drivers in OBs?
I am talking about OB applications where there is no box to load the full range driver at low frequencies. A single full range driver in a modest sized baffle will not produce decent bass, you need a helper woofer. In that case a crossover on both the woofer and full range driver will get the best out both drivers, you will be playing to the strength of both drivers and limiting the frequencies where they struggle.
Just paraphased from the Lenard Audio Institute:
3 laws of Crossovers
- It is not possible to stitch 2 different speakers together, perfectly.
- A crossover should have the minimalist complexity to achieve the desired outcome.
- The more complex a crossover, the more difficult the system is to control.
We both scored!
A nice pair of Zenith 49CZ852's came up for sale on that auction site, so I snapped them up. I'm happy with my find, but I could see my way to trade you straight across for the Vandy's.![]()
While satisfied to a point with the bass in my novice set up unplugging the FR speakers and listening to just the woofers with the Dayton the sound is terrible. I'm positive I have the Dayton wire incorrectly ( both woofers are connected to the sub out plugs )So, I made a big change. Removed the active crossover and the plate amp. Now running the SET pushing the FR speakers using a transformer volume control, wired up the Mac 275 with an active pre amp to the woofers. Much cleaner sounding bass. I need to figure out how to incorporate the active crosser on the woofers next. We went to a concert last night and I got an earful of live music so today is comparison day. Glad it's raining.To avoid a passive crossover I tried an active on the HF and LF. While it might be technically accurate it was a compromise I couldn't tolerate. With the active in the signal path my SET amps driving the full range speakers totally lost their magic and sounded like cheap solid state amps. I still use the Ashly active but only on the woofers. For resolving detail at low levels ( primarily acoustic jazz ) my system certainly works for me.
As long as you don't play any Opera you should be safeThat's a bad thing at my house, skylights in the listening (living) room
Roscoe
As long as you don't play any Opera you should be safe![]()
We both scored!
Yeah, he obviously did his home work before listing them. Apparently word has gotten out - Way to go Poultrygeist!![]()
