LF cutoff will be determined by the shortest dimension of speaker to edge; just bear that in mind.
Minor correction...the frequency were the LF cutoff begins will be determined by the shortest dimension. It will be a much more gradual curve if offsets (vertical and horizontal) are used so the point of audible loss of LF may be somewhat lower. With no offset the curve will be pretty steep and easily audible.
Or you could build a horn....
LOL! Is that what you guys changed the sign to after we left?
...Did it lower the price any?:
Isn't Comb Filtering more of measurement anomaly thats cancellation effect is not readily identified by the ear/brain anyway?
RC
It's a real effect, not just a measurement anomoly. Audibility depends on a lot of factors including frequencies affected (driving spacing, crossover, etc.), room effects, array size, listening distance, hearing sensitivity, etc.
I've build line arrays that had measurable comb filtering but nothing audible and I've heard some where the comb filtering was like a kick in the face
(not a Chuck Norris kick obviously, or I wouldn't be here).
because you are just playing around.. why not find out what those drivers really could do. by fitting a open window with cardboard and putting the driver in the middle.. then playing them..
Heck, just a solid door into another room, like the guest BR when your mother in law is over---
listening tests start at 3:15am, sharp...
