aidynphoenix
wow that was a fast reply haha
When you put 2 speakers in series you increase the inductance, thereby dropping the high end frequency response (lowering max speed).
Having higher inductance would cause the effect of the first order low pass filter to start at a lower freq, effectively decreasing it's high freq performance.
so what if the speakers are in paralell.. the total impendence seen by the amplifier would be lower but the speakers wouldent move any quicker would they?
thanks you dnewma04 i see what i was misunderstanding..
but understanding how inductance effects the freq..
doesent exactially explain what i was trying to ask in the begining..
i didnt mean speed as frequency i ment how well the woofer's movement can follow the frequency..
lets say that you are only useing your woofers in the low frequency range..
if you were doing a 1hz test on your woofer, and measuring the speed at which the woofer could move from the resting position to the extended position and back again.
might a lightweight woofer perform better than a heavier woofer?
or does that kind of speed soley depend on the enclosure and airspace/pressure behind and in front of the woofer?
