Optimus subwoofer needs some work? Help
I have this exact model. At this point, it is not worth the effort. Cab is too thin. Driver is unremarkable. Will definitely need a recap. You could power it w/a plate amp, but at the price of an amp, you could get a whole sub that would smoke this thing.
Time to let that sleeping dog lie.
Yeah I figured this much glad I didn’t PAY anything for this one but It’s lame that they would even design such an low quality sub . When I had it hooked up in my bedroom onkyo nearly destroyed it haha . That was hooked to front or surround speakers ran full range .
This was a defunct radio shack brand ???
So many budget subs are better then it .
ITs just speaker inputs the old type , if you google the model you can’t see .
I have no unused amps , this stereo is old cannot add a preamplifier .
If it won’t strain my amp , I can just use one or both speaker ports to power it ?
We’re talkings about very easy to hook up gear. I’ll get you more pics
LOL I just "assume" everybody here has extra gear laying about unused. :)
Doesn't matter this is they way it was done back in the day and it is still the preferred method by REL for there powered subs, using the High Level inputs, looks like this.:
That should help ..you'll just need lots of speaker cable and take your time. :)
Yeah I’ll see how it runs , what does bass boost do? I run the old Sony groove or v groove boost , there’s no bass without it on is it like a loudness button ?
I have no idea what that is??? You'll have to get some feet for it or space it up a coupled inches, it's not designed to be face down on the floor. Or I suppose a couple inches away from a wall, woofer facing the wall, should work??
Most likely it would make a bigger difference with smaller "real/true" bookshelf speakers than larger ones??
But you'll have to hook it up to your gear to see what it does?? If it's to boomy ... stuff a pair of socks in the port! It sounds silly but it kinda works! :)
Looks like a downfiring sub but someone who owned it previously brokenthe pegs for that , so will use it front firing .
I never turn that old amp up 100% anyways it’s too loud so I’m sure it can handle a old subwoofer.
Thanks for the help , my fronts speakers hooked up are old rtr with Dayton heavy duty woofers. These woofers sound way better then wimpy originals but eventually I may need to upgrade the tweeters and crossovers .
I blew an original woofer Just to realize it was easy to fix just exceeded xmax : works now but not in use .
The images of it online, seem to indicate it is a passive sub. It's most likely an 8 ohm passive subwoofer so an easy load to drive. If you'd post pictures of the inputs ... we could stop guessing. :)
It's not really worth "fussing" with for the most part?? But if you want to use it with another system you can. You run speakers to the sub from the amp and from the sub to the speakers and your done! If it proves to be too "boomy" stuff a pair of socks in the port.
And sure you could drive it with a separate amp but for that sub, it would be overkill?? Now if you happen to have amps and stuff laying about unused and want to set something up just cuz you can ... that is different?? But we'd need a lot more details on the gear your using. My moto is KISS. I'm ticked off now cuz, I had to go from two buttons, AVR/TV to uh three, TV, Preamp and a Power Amp to turn the TV on! First World problem ... sometimes life is tuff?? :)
It sounds fine hooked to my old stereo
Are these plugs for clip speaker inputs ? https://www.monoprice.com/product?p_id=5973#QuestionsandAnswers
Thanks
You're not going to find anything much better than the SI subs, unless you fork out the money for one of their HST models. They are incredible.
5BD837A9-86FC-476F-ABDB-01578A654869.jpeg 8E52CAED-CEE9-4D22-9BD7-9D47CF862182.jpeg 6CEBB189-27B6-4856-84EA-D36FE0E4A603.jpeg
My stereo integrity is in my bedroom if I find a job for a second one I’ll probably no longer use any of my lower end subs . Optimus is in basement , hooked to a obsolete Sony stereo hifi receiver .
I might get a HST someday thanks for info !!:banana:
