Where can you buy the Digitrac cartridge? Also, why don't you consider the AT95E instead of the AT71E? Price isn't much more, but you get a lot more.
Don't get bogged down with the Digitraks now. The OMB 5E is fine and has gotten good reviews here. Thakker's a great seller to deal with. Later you can buy whatever stylus you want to upgrade it.
Yeah, but is the AT71ELC any better?
Sorry, but I don't have an OMB5E to compare to my AT71ELC, so I can't make that direct comparison. I have tried other Ortofons with mixed results. I am quite happy with my SuperOM body and Digitrac 200 NE stylus; I much prefer it to the Ortofon stylii I have used on the cartridge.
I do agree with Howard that the OMB5E is probably a better first cartridge for you than the AudioTechnica cartridges because there are more options to "upgrade" the cartridge with a better stylus down the road, when you have more to spend on your system.
Thanks,
Any body have any other opinions?
Thanks a bunch. I will purchase one tomorrow. However, you said "Just get it installed and set up right, drop the needle and start listening." I am new to vinyl, so how do I install and set up a cartridge the right way?Lots of threads recently about which cartridge might be "better" than another, and the carts under consideration are all in the under $100 range. Frankly, I think as long as the cartridge is an elliptical stylus or one of the variants of elliptical, and the cartridge tracks comfortably in the 1.5 gram range plus or minus a couple tenths of a gram either way, you're likely not to go wrong. Just get it installed and set up right, drop the needle and start listening.
Most of these cartridges are going to have a slightly different sonic signature. For me to tell you which is best is folly, beyond the cartridge being a decent match for your tonearm. None of them are going to be the last word in resolution, or reproduction of frequency extremes. They'll all likely track decent or better, assuming they're set up well, and have other relative merits or small minuses that might not matter that much at the end of the day.
All the ellipticals are reasonably good suggestions, and we can lengthen this and other threads by many pages splitting hairs. Just go buy one and enjoy!
Thanks, I like you. ;-)Technics are relatively easy. The cartridge / stylus is set up correctly when it is positioned in the headshell 52 MM from the tip of the stylus to the outside face of the rubber washer in the stem of the headshell. That will get you started, along with setting your tracking force and anti skate per the cartridge maker's suggested values.
I"m assuming you've got the manual for your turntable. If not, go to vinylengine.com, register, and then look in their library to see if you can download your turntable's manual there. Registration is free, as are the downloads. Set up instructions are there as well, likely with graphics that illustrate the set up described above.
Search this forum with the key words "alignment" and "Technics", and you'll find other suggestions to fine tune your set up. Tinkering on your own as long as you're careful is also generally harmless, and you learn by trial and error. This is not necessarily an exact science.
Now, go have fun!
Actually, I bought a P-mount after being referred to by an "expert" and the 4 prongs ended up being too thin. Here is a picture of my turntable with the neck and the original cartridge (Empire TC40) which fit (The cartridge has no needle; broke a few years ago).FYI - I notice your Technics has a straight tonearm, not an S shaped arm. I assumed we were talking about one of their S arm tables, so ignore the 52 MM stuff I previously posted.
You've need a "P-mount" cartridge. The good news is that P mounts take most of guess-work out of cartridge set up: you just plug in the cartridge, set the tracking force and anti skate, and play.
The "not the best" news is that your choice of cartridge will be more limited. However, there are still many high quality choices out there. Here are some examples in the vicinity of $50:
http://www.lpgear.com/Merchant2/mer...Product_Code=LPGATSER05&Category_Code=LPGCART
http://www.needledoctor.com/Audio-T...3eSbNmTb3mTe34Pa38Ta38Pahz0?sc=7&category=910
http://www.amazon.com/Grado-Prestig..._m=ATVPDKIKX0DER&pf_rd_r=072RDQ4D9YPESX5HMHZR
There are more choices out there. You can Google "P Mount Cartridge" or "TP4 cartridge" for additional options.
OK, well you DO have an S arm after all. I picture is worth 1000 words, I guess.
We're then back to the 52 MM from stylus tip to rubber washer, and a wider array of cartridges to choose from. Its all good from here.
