6l6gmike
Background info: I am refreshing my Garage/Autoshop amp. I have tube amps and preamps everywhere.
I am running russian spec 6l6g on it and they are driven by a 6N7 long tail that is driven by a single triode voltage stage, the whole thing is similar to a Mullard 5-20. Anyways I want a little more oomph from it. I was going to rebias it according to the RCA manual suggestion. Right now it puts out something weak and disappointing (I don't recall what it really does and I haven't tested it yet) Output trans are 8.6k 21 watt Edcor and I do have a fixed bias tap on the power trans.
On to the questions.
Thank you.
Mike
- Do you think (if my driver can handle it) I get the rated 26.5 watts shown below using the numbers they posted?
- Also are those wattage figures in RMS?
- Is this wishful thinking in the datasheet?
Thank you.
Mike
