6l6gmike
Ok I have lots of different 6l6's of different makes to try and I do have a rebuilt and calibrated BK500 tube tester. I modified with paint an existing print that I got from the internet 4 years ago and no idea where. I kept some resistor values blank because I don't know what the values will be. Also I was thinking it might be fun to use gas tubes to regulate the 250v grid but that will require some more research. So here is the schematic that I came up with. I know I could do a solid state current in the tail of the ltp but I want to keep it simple. Let me know if you see any big issues with the posted schematic. Sorry for the paint / crude-ness of the print.
while you work. That way you can hear the music better and reduce the noise from the power tools at the same time, which has got to be better for your hearing and it's much simpler than modifying your amp in order to get such a marginal increase in output. I can't imagine that, under such conditions, you would notice a meaningful difference in sound quality.
Let me know. Thanks.
But I still haven't figured out how manufactures rated tube amps back in the day.
Otherwise I am open to tube and non-tube suggestions. Simpler the system the better it is for me. I have plenty of heater current and some room left in that amp.
