PA1002A workaround / replacement
Thanks for the information.
But unfortunately, the SX-980 isn't complete without FM muting.;)
I'll build the following version, test it, and report back.
I am very late to this thread...as I begin to sort out my own Sx980. Just incredible work by all I must say. A huge BRAVO to everyone.
I have seen the replacement boards, components and fully stuffed versions all available on ebay from Ben which is great.
Then I find this thread and the latest posts aimed at incorporating the muting into a similar package - magnificent.
So....not0815 ..any success with the circuit you proposed above?.. did you build and test? ...
I've had no response from Sven(not0815) above about his solution above...so decided to search around a bit more. I note in several places that a PA4004 could well be a direct replacement for the PA1002...with or without the A ..unknown? I've seen a few pics of receiver tuner boards with a 4004 fitted where a 1002 would normally sit.. so figured must be some truth to it.
I cannot find much more info about it ... certainly no datasheet sadly. Anyway..a quick search online and I found a PA4004 on the auction site, in Europe for a little under €30. I promptly clicked and am now awaiting its arrival. For €30 gotta be worth a shot.
Until it arrives and I get to fit & test it ... is there any info available about why these 1002's fail so readily?.. and more importantly...how we might prevent it? ... I've read every PA1002 thread on AK but cannot see anything that might throw some light on this.
Obviously..the last thing I want to do is find one of the (now v. rare) single chip solutions...have it fitted and working for a while...only to have it fail only a little further down the line.
Wondered if any of the experts had spent any time figuring out why they fail...and what we could all do to help prevent it happening. It might just be a simple solution..an extra cap ...a slightly higher value somewhere that protects it a bit more. ..I am speculating..but you get the idea.
cheers all
Graeme
Dear Audiokarma members.
I am 65 years old and still passionate about electronics. I have been working in this field for 51 years. Last year, I purchased a Pioneer SX-980 receiver that was in excellent condition and had never been tampered with, but was malfunctioning. I repaired the power amplifier stage. The only issue is that the PA1002 is defective. I’m going to replace it with an OPA1656 or 2134 op-amp circuit. For this reason, I’ve sent messages to three valued members on the site. I’m also letting you know about my PCB request. Customs procedures in Turkey are very problematic and tedious. There’s no issue with regular mail. I need a mini PCB that will allow me to replace the PA1002 with OPA or TLE components. Dear friends, I’d appreciate your help.
@ta2cj
assuming it is avail in Turkey - you should search eBay auction site for the ready prepared diy kit to enable what you want.
peace.love.and.music is the seller ...and also a contributor to AK. All parts necessary are contained...inc. the OPA2134 opamp you desire.
This will almost certainly be shipped from the US using normal post.
Sounds like this would serve your needs exactly.
I am still waiting for the PA4004 to arrive from Europe ....to replace my own non-working PA1002.
Whilst I wait for it I noted something of interest whilst working on a SX680. The 680 uses only the 2 usual suspects for its FM..the PA3001 & PA1001. The 1001 in this 680 wasn't working and so I replaced it with an MC1310P. With a few small modifications...it works well.
What I noted was that the inter-station muting still works VERY well... and that is without a mute function on the MC1310P. - the mute feed from 3001 to pin 8 location on the previous 1001 ..is now an open end...it goes nowhere ..and yet inter-station muting works fine. I figured it therefore MUST be the 3001 that looks after muting on the lower models like the 680.
Looking at the schematic for the SX680..it shows the mute output at Pin 12 of 3001..not only went to the 1001...but it also runs around to its own Mute IN ..on pin 5...via the mute on/off sw. see the SX680 diagram below.
So...seems to me...in the case of those receivers using the PA1002, that are now not working...and that have the gain stage opamp board fitted - the missing mute function could be acquired by using the 3001 in the manner the 680 uses. Might need a little off-board rewiring to bring the mute on/off switch into play..but thats no big deal.
I havent tried this yet in practice...but I see no reason why it cannot work. If my ordered PA4004 doesnt arrive soon I will make up the gain stage opamp board, fit it...and rewire the mute as I suggest above.
Obv. this only takes care of inter-station muting .... any power off/on muting should hopefully be looked after by the protection circuit relay.
