Got the TDS7104 working. This thing was a bit of a basket case.
1. Did not power on when I got it. This was due to the CMOS battery on the Intel PC motherboard being totally dead.
2. Once the battery was replaced I could turn the unit on, but it wouldn't boot. It was not detecting the hard drive.
3. I was unable to get into the BIOS by pressing F2 to enter BIOS setup. It would acknowledge the keystroke but continue the boot process to nowhere.
4. I had to download an ancient MS-DOS utility called "KILLCMOS.COM" from MajorGeeks (man, haven't used that site in like 25 years), and put it on a Win 98 boot disk. Running this tool apparently deleted any corrupted CMOS config and allowed me to get into the BIOS setup.
5. Confirmed that the HDD was not being detected in the BIOS. HDD was making a clunking sound when I took it out, so I thought it might have been bad. I connected it to a dock on another PC and cloned it's contents to a file - it was fine. I wrote that image to a new CF card and installed it in the scope with a CF-IDE adapter. Still not detected.
6. This scope uses a quick release hard drive sled. I took that out of the picture and plugged the hard drive directly into the cable that goes to the motherboard and it booted. I reflowed the connectors on the quick release adapter and tried again but that did not change anything. It turns out that the 1" long IDE cable on the sled was bad. I ordered another on eBay. I could have just double sided taped the CF-IDE adapter in place but I like to do things right.
7. Windows 98 booted but the TekScope app just hung and didn't start. This is a common issue on these scopes and usually indicates that the Dallas NVRAM "PowerCap" battery is dead and the scope loses it's VxWorks boot config. I ordered a new PowerCap module anyways, might as well swap it out now so I don' have to pull it apart again in the near future.
8. I bought some cables to be able to plug into the PowerPC Serial debug port to check out what was going on with Vxworks. I have no idea what happened but after poking around in there (and not doing anything) the scope is now starting fine.
9. Thankfully the actual scope application itself works perfect. It passes all diagnostics and the SPC. All of the inputs work as expected.
10. I need to figure out how to replace the power button. I am hoping Tektronix has them in stock. A few other people mentioned recently that they still have parts for these scopes! I asked for a quote on all of the knobs/buttons on the front, the front panel (the tabs are cracked on mine) and the power button. That would be awesome if I can get them since it will look brand new.
11. The LCD backlight is pretty dim compared to my TDS5054B. I have a parts unit TDS5054B I may try swapping the LCD out of - but I'm not sure of it's condition. Worse case I should be able to change the ccfl tubes over to LED's.
