AvFan
Rothwell is entirely right in this. I model my MC cartridge/pickup arm/SUT/preamp extensively and getting a good match to the actual frequency response and how it behaves as load is changed is quite tricky.
Below is a SIMPLIFIED model of such a system, just to show how complex it is. Caveat emptor...
I recall you saying in the past you'd spent some time on the cart/SUT/preamp analysis. Wow! I will have to be satisfied with far simpler attempts. Like...trial and lots of error.
Of course, it would make sense to treat the cartridge and transformer as an integrated system and fine tune the performance that way, and in that sense these tests are valid. Just be wary about drawing universally applicable conclusions from them.
I better understand what you've said about loading the secondary side of the SUT. I can't tell from the photos if adding resistors reduced the output and the calculated load isn't correct because the SUT is now part of the system when resistors are added to the SUT's secondary side. So if I want to add resistors on the primary side of the SUT to load the cartridge what is the formula? Will this provide an accurate load on the cartridge?
Lastly, Jensen and Sowter show Zobel networks on the secondary side of their SUTs without knowing what cartridge will be used. Do you think these networks are approximations? Since the values of the resistors and capacitors are similar for both manufacturers can we draw any conclusions about how these networks perform based upon a SUT's turn ratio?
