Parks Audio Budgie Phono Preamp
Just got one of these, stock tubes. BIC TT, Pickering Cart, sounds kind of flat on setting 1. Any ideas?
bob
I run Pickering carts. With a new-ish stylus and proper alignment, those sound good 47k, which is 1-0-0-0 on the Budgie
I got a used one of these a few months ago. I'm just using the stock tubes, run it with an Signet AM10S cartridge with a VMN40ML stylus. It feeds a Parasound ZPre3.
Let me start by saying, it is the best sounding phono stage I've tried.
But I do have some test albums with pink noise tracks, both the HiFi Producer's cut as well as the CBS STR-140. And while cheap SS phono stages measure essentially flat out to nearly 20k, the Budgie starts to roll off at approx 10k and is down about 3db by 15k.
And I'm just wondering if the test records are crap, or if there is an impedance issue with the ZPre3 (24k btw) or something else?
I keep my total impedance (interconnect and tonearm wiring) around 83pf, plus whatever the Budgie contributes. I'm running at 47k. If I increase that, I start getting a lift that starts as low as 6 or 6k (IIRC), so less flat midrange.
It is just sort of a curiosity. If someone told me a way to make it measure flatter above 10k, I'd likely decline because I like the sound as is. I can't hear much above 15k anyways.
But, any ideas?
But, any ideas?
I had a Budgie and I liked it, in particular the loading flexibility and convenience of top mounted dip switches. The ability to increase the load from the typically fixed 47Kohm was very handy when loading a MC cart while using a SUT.
I wonder if the Budgie's high frequency rolloff is intentional. I have no idea about your cartridge but this TNT Audio article describes the high frequency rise of a Nagaoka cartridge that would be offset by the Budgie. The capacitance of the Budgie is fixed so maybe Shannon Parks designed the rolloff for the typical MM? Is it typical for MM carts to have high frequency rise like the Nagaoka? This TNT article might provide some additional insights regarding MM cartridge loading.
It could be, but Mr. Parks referred to the RIAA accuracy.
I've never used a tube phono before so don't know whether this is typical or not.
I had figured it was an impedance matching issue but see Mr. Parks ran it on something with a very low (9k?) input impedance back a few pages and indicated the unit measured correctly.
This would be a bit of a non issue except I designed my own tonearm and use the captures to compare recordings before/after incremental changes in my arm. So having a flat preamp would help in that regard.
Thing is, the Budgie sounds so amazing.
I'd send Shannon an email and describe what you are measuring (hearing?). He was very responsive when I had a problem with my Budgie.
I rolled out the stock Electro-Harmonix 6922 tubes for a pair of NOS Amperex 7308s and the Budgie's performance stepped up. There are lots of tube options and Shannon can offer some suggestions.
The stock EHX are nothing to sneeze at providing they are still at or near spec. Even preamp tubes wear over time.
I am running NOS BEL E88CC in mine.
So, my Budgie has an intermittent weak right channel. I have swapped TT's, inputs, outputs, cables, reversed the tubes, and it's always the right channel. Not sure what else it could be besides the tube?
bob
So it turns out there was a change made during production that inadvertently added over 400-pf of Miller capacitance. The solution was lifting one leg of a capacitor between pins one and two on each tube socket. Now the unit measures as flat as any of my other phono stages, and sounds even more fabulous.
Who'd have thought. I was getting this low level thump thump thump pulsing sound. Turns out it was, I assume, the tubes picking up the 2.4Ghz signal from the router. ASUS AC68U & Genelex Gold Lion Tubes.
My Gold Lions are doing the same with my Internet Provider Supplied Router. Swapped Router out for an aftermarket TP-Link Router and the pulsing is gone so I assume ISP Router is using cheaper non-shielded components than the TP-Link. Also noted that my Sovteks from the 80s, JJ Gold Pins and EH valves don't pick up the signal so who knows..
How to tell what units?
Have to look inside. From Mr. Parks:
At some point during Budgie production (years after the design process), I lowered the noise floor by adding a 15pF cap from pins 1 and 2 on both tubes. I neglected to account for the Miller capacitance that this little mod created (435pF!!!), as I was "outside the design time frame" and subsequent tests didn't reveal any frequency response change. You see, my QC testing happened with a low output impedance source (very little inductance) so the RIAA from 10kHz to 20kHz was spot on, unlike what happens with a much higher inductance cartridge . It wasn't until I was winding down production to switch over to the Puffin that I discovered my mistake. That said, I think this error contributed a bit to the sound that folks liked - interesting how that worked out.
Anyhow, you can flatten your Budgie out by just lifting one of the legs of the 15pF yellow, axial capacitors (by V1 and V2 pins 1 and 2 - at C21 and C22). Could just snip one side and lift, too. You could then easily resolder the snipped section to go back if desired.​
That's a nice revelation. Was the difference noticeable? I'm wondering whether or not to do that with mine now.
Yeah, it is definitely noticeable. Without the added Miller capacitance, I am able to use the loading resistor switches to better effect.
Here is before/after, both at 47k. I would have spent more time working on loading and getting an even more flat response, but switched to another preamp because I was working on another aspect of my system.
  • Like
Reactions: GPJ
The caps I am talking about, were soldered directly to each tube socket's legs. Can you look on the other side of the board for caps added directly to the legs?
Ah, interesting. I believe we have different board revisions. There are no caps on the other side. I have a rev C board which must be a later model. From looking at pictures on the web, the earlier boards are missing the yellow caps where mine are. My unit has a carbon fiber top and the power switch is in the center also.
I will assume from the post you made where you quoted Shannon, that I have the correct caps identified. Mine are located between pins 1 and 2 and have labels underneath that are C21 and C22. So, I think I am going to give it a try.
Many thanks for posting this information!!!
Ah that makes sense.
Please follow-up and let me know your thoughts.
