Theophilus Punoval
The Queen says it's OK...
This question has probably been asked and answered before, but here goes anyway: What are the advantages/disadvantages of passive radiators?
Advantages: They look like great-big woofers, yet they don't cost or weigh as much as active drivers.
Disadvantages: Like all "ported" or "vented" systems, the bass goes out-of-phase as the frequency drops.
Interesting video, thanks for posting.
It partially answered a question I had... does anyone still use that technology. I thought porting eclipsed passive (bass) radiators in contemporary speaker technology.
The good ones can be tuned for the FS you are looking for!
That's exactly what I thought. There were many companies that used "bass radiators" back in the late 70s to early '90s though I've not seen any modern speakers using them. ESS, Polk SDA-SRS 1.2tl, Epicure 202 and 500 and many others but I cannot think of one today that uses them.
Most speakers produced today are ported with very few being suspension that I've seen and even less using the passive radiator design.....
Think of the PR as a tube port substitute. Depending upon the woofer parameters the vent needed to tune down to a desired frequency can result in a very long port tube. The PR can most often tune lower using mass rather than larger port dimensions. So the designer could use the PR when the port dimensions for a desired tuning are too large or impractical for the enclosure dimensions. The there is spurious noise containment as mentioned. Also, open vents can unload at low frequencies with the risk of over-drive failure and added warranty expense. Disadvantages are added cost for the part and fitting same. Finally, placing the component in smaller enclosures can be a problem.
"The lower-priced GoldenEar towers use quadratic planar infrasonic passive radiators."
My bilateral ocular sensors immediately suffered an effusion of hemoglobin while scanning that phrase.
