I am thinking of replacing the single 6th order vented bandpass box in my Nissan truck, with a pair of slightly smaller bandpass boxes (for stereo bass).
The only issue, is that the ports required to do that, would be prohibitively big, and take up WAY to much box volume. In fact, the current box was about as small as could be done, and still have reasonably low vent velocity. Using slot or pipe vents in an even smaller enclosure- well, that just ain't gonna cut it...
So- I am planning to do a pair of passive-radiator 6th order bandpass:
Each box will have an internally mounted 7" woofer (probably a Dayton Audio), and a 7" passive radiator tuning the front chamber, and a second 7" passive radiator tuning the rear chamber. Should be able to get down to 22 Hz f3 (!) before cabin gain is considered- and even lower, in vehicle. With two of these, it should be PLENTY of output (should be about the same as a pair of 10" in sealed boxes, only with more low end extension). And the boxes will only be about 7.5" tall... leaving plenty of space behind the front seat in the truck, for tools, luggage or other stuff...
Regards,
Gordon.
Well, this project has changed.
I decided to make the cabinets, where they sit on top of the plastic compartments on each side of the rear area (where the jack and such live), right against the jump seats on each side. Here's a cross-sectional diagram of what it's going to look like:
The "cutout" in the bottom corner, will allow the box to sit on top of the plastic compartments. I think I can actually attach some hooks on the sides of the box, to use the seatbelts for the original jump seats back there, to hold these in place- which will allow easy access to the jack and tools, whenever needed. This also allows the middle space behind the front seats, to be completely empty- nothing will have to sit on top of the boxes.
This is using some different drivers now- the Dayton DS165-4 6.5" subwoofer, and a pair of the Dayton DS215 8" passive radiators, per box. It will actually go lower than the box I originally spec'd out. And the cool thing? With the 8" passive radiator- the cutout is 7.125" diameter- larger than the outer diameter of the woofer. I can remove the woofer through the passive radiator hole, if needed. No need to disassemble the box- just remove the PR, then remove the woofer...
Regards,
Gordon.
