djchaseb
The manual doesn't mention an auto-standby mode, but as they're active with an internal DSP it's not unusual for a DSP to auto-mute if it thinks there is no input signal. If you've an ADC, likely the easiest way to test this is to record from the line out of the phono pre and see if the noise level changes at all. If it doesn't, then it's something with the monitors. Or maybe Mackie support can tell you.
It's not extraordinarily difficult to get a vinyl signal chain to be pretty quiet, but I don't think it's achievable with what you have, and near field is going to add to that challenge. If your recording is at/near full volume on the Mackie's then I probably wouldn't find the level of noise you're getting to be odd. The only odd part is that it cuts in and out.
I can also trigger it by turning the switch on and off for the ceiling fan, same thing, a short temporary buzzing, that's with the tonearm parked and not touching anything. Just a bunch of strange stuff. Going to do my best to just enjoy my records at this point. None of my gear is top tier either, can't expect too much from it
