What are your cables between the TT and the preamp?I'm using a simple Technolink TC-750LC preamp which is output to a pair of powered Mackie Monitors.
In cables where the shield is only connected on one end, isn't that end typically the source end (in this case the turntable) rather than the destination (in this case, the preamp)?Yes, clever.
By the way:
While you are at it, - I'd suggest you do a pair of shorter RCA-to-RCA runs with something like the Canare L-2T2S.
Cut that cable as short as your rig permits, solder it between the two RCA jacks so that the white wire on both ends is connected to the central RCA pin, and the blue (or whatever the actual color the wires in the Canare cable are) wire is connected to the RCA's outer barrels.
Connect the shielding braid to the RCA's outer barrel on only one side, - this cable end should plug into the preamp's input. This is for one channel.
The other channel is to be connected with another cable of the same design.
The main idea here is to have each channel to use a shielded twisted pair with the shield and the"cold" wire being grounded only at the preamp's input.
Then, with the separate ("black") wire connecting TT's ground to the preamp's shield - you will have the lowest possible hum pick-up.
I’m using monoprice 3 foot. Not sure how good they are, seemed better than the standard run of the mill RCAs. I can possibly move the preamp closer to the turntable and get away with 1 foot or less.Yes, clever.
By the way:
It is not the source end.In cables where the shield is only connected on one end, isn't that end typically the source end
Don't know what a monoprice is, but three feet is way too much for any cable. You are adding at least 70pF to the input capacitance.monoprice 3 foot
It is better to have the preamp built-in, then you could significantly reduce the input capacitance and increase the input resistance. Doing so you will get the flattest responce all the way up to ~25kHz (where your Ortofon OM5E has the needle+groove resonance) and a bit less preamp's noise.
Please clarify... I'm not sure what you mean. Are you suggesting that the shield should only be connected at the destination end, or that the turntable is not the source end?It is not the source end.
The each cable shield should be connected to the "cold" wire on the cable end that plugs into the preamp's input.Please clarify.
Yes, I forgot that. I saw Ortofon OM5E being mentioned on the U-Turn's site, that's why I referred to it.the cart was an VM95E
There is a nice LCR-calculator somewhere on the net, it shows the resulting frequency response for various cartridges under different C and R loads. If the Cload is made very small (~twenty picoFarads or so) then Rload may be made into hundreds of kiloOhms - which is beneficial in terms of noise.
Alas, I did not keep the Stylus 10 response where - along with the usual LRC-peak - the 24kHz high-Q needle+groove peak was clearly seen.It'd be good to see some actual measurements for what you're claiming in regard to that stylus
I'm talking about the needle+groove resonance only.
I had to edit the model (Rinp==33kOhm) to make it easier to see. With the Stylus 10 it sits at ~24kHz, I saw it with SpectraPLUS-SC.
With the Stylus 40 I do not see this peak (with SpectraPLUS-SC) under the same conditions in my preamp.
This model does not implement the cantilever's own resonance, so the bulge just above 10kHz is the LCR peak from the inductance and capacitance.
When I properly implement the 75µs time constant by the L×R, this bulge will disappear. Yes, the cantilever's peak will remain, but will it be as prominent on the frequency response? Or will it only affect the channel separation? I do not know yet.
