I'm still not ready for my Stylus 10 rip.Whenever you have it, I'd be curious to see the data.
Thank you very much for analysing my rip!
Did you apply the B&K's correction (that is necessary with their QR2010 test record as well as with the record I used)?
When I use that correction with the SpectraPLUS-SC I get a bit flatter plot.
Could you check - and give your opinion on what's beyond 20Hz~20kHz limits? I have not got B&K QR2010 to measure the tonearm+cartridge resonance, I can only see its' there but can't measure how bad it actually is.
PS
The nasty curve at 400Hz must be SL-J2's plastic tonearm flexing out of shape. As soon as I manage to tame the ~13Hz peak, - I will try fixing that "fishing rog" thing.
PPS
This offtopic should be moved to the "30 vs 40" thread, where it is more relevant.
PPPS
Could you please share your plot-viewer tool?
This guy promotes his low-noise wide-band RIAA preamp by showing some rip spectre. He used an AT-91 cartridge - with very heavy needle (a bonded conical).
I mention this because the spike at ~16kHz in his demonstration resembles very much the spike I saw at ~24kHz with Stylus 10. And this spike is gone as soon as I installed Stylus 40.
I'm sure - this is the groove+needle resonance we should avoid by all means.
Alas, the author of that correction pased away recently, so I missed the opportunity to ask for the proper usage...The correction file looked odd to me so I took some time to analyze it today.
I'm not sure how this is applied as with a RIAA phono stage there should be no correction below CV as T1&2 are used to cut the record.
Thank you, I will use this script now instead of the SpectraPLUS-SC's built-in tool.The script I use is at https://sjplot.com.
Yes, the spike I saw with Stylus 10 was way much broader. But it too did not depend on the audio contents.Far too narrow for that.
He suggested two other variants of corrections (see attached).
If you have time for that, - I'd be hugely grateful for your analysis.
