Steven Tate
CEO Flat Forehead Soc.
I have had recurrent problems with low frequency "motorboating" on several 2230/2245/2270's after updating the phono boards. There has been a lot of discussion about it here, with no definite fix determined that I could find. The closest I have come was thinking that the KSC1845's often used to replace 2SC458's were not as good of a match as KSC1815. In most of my cases, when I had the problem, I had replaced the 2SC458's and the four 2SC1000's with KSC1845's. That muddied the water a little bit as to the source of the problem. Well, today I had a 2245 that I did a complete recap/restore on about two years ago and has been sitting on a shelf since then. I wanted to check it out from top to bottom. Everything was wonderful until I got to the phono. In my case, what usually happens is that everything sounds good when I put it in Phono mode. Then I hit the start switch on my Dual 1229 turntable. During automatic translation of the tonearm, the turntable shorts the leads from the cartridge to block out the noise caused by arm movement. As soon as those contacts short, loud, low frequency motorboating starts. It continues until the tonearm sits down, the shorting contacts open, and then the music sounds perfect. I found the turntable didn't matter as long as it was automatic and shorted the cartridge during tonearm movement. I tried my Marantz tt530 linear tracker and got the same noise while the arm was moving. If you removed the turntable, and just short the RCA cable, you get the same result. Well, this time, there was a difference. The right channel did not motorboat, and the left channel reliably made the sound. Also, it turned out I had only replaced the 2SC458's. The 2SC1000's were still in place, so it removed them as a variable. I loosened the board from the chassis, and as long as it was 1/4" away from the standoffs, the motorboating went away. But if I pushed it toward the standoffs, just before it touched, the left channel would start doing it. It was completely repeatable. I looked for wiring problems to no avail. If that board was near the standoffs, it was going to motorboat on the left side. So.....I removed the KSC1845 on the left channel and replaced it with a KSC1815 with little confidence that would solve the problem. But I fired it up, shorted the inputs and zero motorboating. I could move the board away from the chassis or push it against the standoffs, and silence. So, I screwed the board to the chassis, plugged the turntable back in, hit the start button, and the tonearm moved and set down with zero noise. I did it several times and it never motorboated again. Why did it do it just on the left side? I don't know. But I'm 99% sure that KSC1845 is the problem. I guess before I close it up, I'll change out the other 1845, even though it doesn't make the noise at this point. Hopefully, it won't screw something up to do it, but I figure both sides ought to have the same transistor. I know in the future, I will be using KSC1815 to replace 2SC458 in these phono boards.
