Sansui Louie
Curmudgeon
So what was the deal...the relationship...between Pickering and Stanton?
The PD07T and PD07C are for the Pickering NP/AC and NP/AT cartridges, which are versions of their V15 cartridge, not the XV-15. Different cartridge. The V15 is an earlier design, and is the Pickering version of Stanton’s 400 and 500 cartridges.
The PDO7-C is a 0.7mil conical stylus and has a tracking weight of 3-7g, while the PD07-T is also a 0.7mil conical, with a tracking weight of 2-5g.
They're the same company, founded by two guys, Norman Pickering and Walter (?) Stanton. They made pretty good pickups. In all honesty, i haven't found any Pickering/Stanton pickup that i didn't like.
You need to be very careful about buying them from either Jico or LPGear, not because they don’t sell good styli, but with the Pickering models, they get confused between Pickering’s XSV/XUV series, which are moving magnet cartridges, and their XV-15 models, which are moving iron models. I suspect the reason LPGear have it wrong is that they’ve copied Jico – or maybe it’s the other way around!
MM styli won’t work properly in your MI cartridge
Glad I checked. The whole moving iron thing does kind of do a bank shot off the "normal" wall, don't it? I'm not all that concerned about HOW it works, just that it does. Very nicely, in fact.
Sounds like my best bet then would be to go with my initial plan to get an original OEM Pickering stylus. Only one I can find is the 625E, which isn't a bad thing. I'll go ahead and order that.
So ... reading between the lines ... the MM stylus WILL work in the XV-15, but not as well?
Makes me wonder about those who say they get good results with the aftermarket styli. Either they got real lucky, or they never heard the original?
It's funny, I'm sure this was common knowledge in audio circles in the 1970's, but I don't remember ever seeing it in print in any of the old reviews I read as a kid. I just remember thinking, "What's the deal with those Stantons and Pickerings looking so much alike?"
Well, it will be OK to buy from Jico or LPGear as long as the stylus numbers correspond with the genuine Pickering XV-15 stylus numbers.
I'm old enough to remember the days when if you said you owned a Stanton 681EEE some audiophiles as well as audio shops would either laugh at you or would give you that look like your kidding rite and then walk away. Boy were they wrong as a lot of them found out later on
LPGear doesn't say who makes their D1200, but I see the description lists it as a "ViVid Line" stylus ... which I do believe is JICO? From what I read, only step up from that would be one of their SAS numbers, and they don't make those specifically for the XV-15 that I can find.
If anyone doesn't believe me, I'll be happy to stick a Stanton 681 stylus on my XV-15 and vice-versa, then record the results. :sigh:
OK then ... given a choice based on what I've gleaned here ... :scratch2: ... OEM Pickering 625E (which seems to be the only one still available unless you get a package including a cartridge) OR the LPGear D1200. Both about the same price, and if I'm gonna go aftermarket, might as well go for the gold, right?
LPGear doesn't say who makes their D1200, but I see the description lists it as a "ViVid Line" stylus ... which I do believe is JICO? From what I read, only step up from that would be one of their SAS numbers, and they don't make those specifically for the XV-15 that I can find. Also, I <think> a line diamond is the NEW! Improved? equivalent of a shibata and should track quad? Be nice if they'd list it as such and take the suspense out of it. Or just say, no dummy, it's NOT a shibata ... now go away or I shall taunt you a second time!!
PS - don't believe I mentioned what happened to the old stylus. Whatever Pickering used to seat the cantilever turned to goo ... big surprise when it slid up the stalk and the cartridge body started skating across the vinyl. Happens a lot? Or is it just me?
