Piezo-Azden-Acutex Thread
Speaking of the bricks, what kind of effective mass is optimal for them? I can get my AT1005ii down to around 13g if I slide the tracking force adjustment weight down to zero and dial the tracking force in the hard way with the primary counterweight.
Sounds good! Do that.
Seriously, since these are medium-compliance styli, they're just right for the Great Middle of the bell curve of typical Japanese turntable effective arm masses, of which I believe my SL-1700 Mk2's arm to be typical. No need to go to extreme lengths to get a good infrasonic resonance point. But it would be interesting to know where your particular arm resonates with the stylus you're using, so grab a test record and see what's what.
On My AR-XA after doing the SME style head shell mod it changed the effective mass of my arm which was around 11-13gr so now its a bit heavier as I needed to add a larger counter weight.
But now it sounds great. I also did some bearing mods as well so that also might play into it. So not sure where my arm mass falls now but it sure does sound great !
nashou
Will do. Meantime, widen your search to include styli for the Empire 350DE. Same animal.
John
This is from way back inthe first page of this thread.
I want to know which empires are Azden/Acutex/Piezo and if they are all Tri poles or not?
Thanks
Athanasios
I don't think any of the Azden-made Empires are tripoles. Most seem to be for P-mount applications. I don't own any so the above is subject to correction.
By the way, Azden and Piezo are two names for the same company, Nippon Atzudenki (hence Azden) which translates roughly as Japan Piezoelectric (ergo Piezo). Acutex, like Empire, ADC, Spectrum and many others were customers. Like Excel Sound, most of their cartridges were sold under other brand names.
ok...Who got the LPM 320 str !!!!!
You went way over what I would have paid !! But congratulations !!!!
Nashou
I posted pics of another re tip I did in my Acutex re tip success thread , this time with an LPM stylus using a sapphire .59mm rod and a mangled cantilever STR diamond.
I had some sibliance and bad separation . The left side was much louder than the right. So I spent a lot of time adjusting azimuth, VTA, VTF, protractor alignment etc. but still had the
louder left side no matter what I did. I decided maybe it was the longer length cantilever I used. But today in the mail came another LPM M315 with a broken cantilever. I buy them for the stylus shells so I can re tip them.
Well I had a thought that maybe its the electrical characteristic of the body that might be causing the issue with imbalance . So I pulled out the multimeters and LCR meters i have to do some testing of the three
LPM bodies I have.
The first one I tested had a DCR reading of about 9 ohm difference left to right( I didn't document which was which :( ) the other two bodies faired better with about 2-4 ohm differnece .
Then I did the inductance , the original off balance body measured a 20 uh difference!!!!! the other two were both less than 10uh . I have other carts of different brands and i found that 10 ohm difference did not
make a difference .
So I ask, is the inductance more important than the DCR for balance ? Obviously if one is off so with the other butt his seemed to be the issue.
Using the best body the balance is much better and for some reason the sibliance also is much much better.
Or is it maybe that body was bad in other ways as well?
Pic of the ugly re tip , using a yamamoto cherry head shell before it was a Jelco metal head shell, maybe that was the sibilance problem?
Athanasios
... the original off-balance body measured a 20 uh difference!!!!! the other two were both less than 10uh . I have other carts of different brands and i found that 10 ohm difference did not make a difference. So I ask, is the inductance more important than the DCR for balance ?
20mH is not enough to make an audible difference, but you're correct in suspecting that inductance is by far the more important of the two measurements-- not only for channel balance but frequency response too-- though it's good to measure both. I'm assuming you're measuring in millihenries (mH), not microhenries (uH). You did the right thing by checking the basic/obvious stuff first.
As for what might be causing the imbalance, I suspect a mechanical misalignment (the sudden change in sibilance was the clue), but keep playing around with it and I'll bet you have a Sudden Moment of Illumination, aka an epiphany.
20mH is not enough to make an audible difference, but you're correct in suspecting that inductance is by far the more important of the two measurements, though it's good to have both. I'm assuming you're measuring in millihenries (mH), not microhenries (uH). You did the right thing by checking the basic/obvious stuff first.
Thanks wualta, Yes its mH . I wasn't sure if the difference in channels was the reason for the left being louder. But with the other bodies, I tried the other one ( second best) and
it too sounds fine. Went with the original one that was further out of balance and again everything went to the left more. Maybe its a bad body then. The other
two sound fine, actually listening to the LPM Sapphire cantilevered STR now with Dark side of the moon underneath it and it sound pretty damn good !!!
Maybe its the jello head shell, thats the one variable I have not tested. The out of balance body is on that head shell for the entire testing.
I even moved them from my AR Xa to my Sota and got the same results. so there you have it ;)
Athanasios
Brick. If you need or really want one of these, you're not likely to find another but, as I said, $265 is too far out of my budget.
It look nice in the collection though, I true rarity.
Just got this for my Acutex collection
Nashou
And I have one of the very rare (aka RARE!!! on eBay) Acutex straight-arm headshells. Makes everything sound better. Like an Acutex! Even if it stays in the package.
I have it on my watch list, thanks.
Any thoughts on getting my stereo separation where it should be with my existing carts? I'm a bit perplexed at this point. I'd say it was something in my setup, but I was getting 20dB + of separation out of my standard MM carts.
What geometry have you aligned to ?
Are your null points based on the actual mounting distance of the tonearm ?
When I first tried an Akai pc-100 that came installed on an Akai AP-206c turntable with a relatively short tonearm mounting distance of 205mm , the typical Stevenson alignment favoured by japanese turntables of this era proved to be the main limitation to good sound quality across the majority of an album.
I was able to eek out a Baerwald alignment based on the actual 205mm mounting distance , by using the full length of the headshell slots, with the short and stubby Akai PC-100 which has a shorter stylus tip to cartridge mounting hole distance than an at-95e for example. It was that re-alignment to Baerwald null points that helped me appreciate the capabilities of the cartridge itself. Might be worth checking the alignment on a protractor to ensure all is well.
