Piezo-Azden-Acutex Thread
Good thinking! I've been using Stevenson for everything as I've mostly used Japanese tables with arms designed around it. Maybe it's a bad match for this cart, especially on short tonearms?
Most of the vintage Japanese turn table headshells have screw slots long enough for the Stevenson protractors but not the Baerwald protractor.
The modern day Stanton H4-S.V2 headshell have the extra long screw slots to accommodate the Baerwald protractor. :thumbsup:
You can take a manual measurement of your existing tonearm mounting distance by measuring from the center of the platter spindle to the centre point of the tonearm's pivot bearings. If you can get that dimension it to within 0.5 mm accuracy then Insert that dimension in the pivot to spindle distance here and press calculate.
https://www.vinylengine.com/tonearm_alignment_calculator_pro.php
You will then know the exact *straight line* distance you need to reach from the centerpoint of the tonearm pivot to the stylus tip to achieve the correct effective length for a pair of Baerwall null points based solely on the measurment you made.
Nashou your Saturn V post elsewhere has me wondering how much adjustment range does it have? Comparable to standard headshells?
Ill post the pics here as well.
I am not sure but it looks like maybe 1/4 to 3/8ths of an inch.
At work now will have to check later tonight or tomorrow.
I don't have a Saturn V any longer so I'm not 100% certain but, as I recall, the adjustment was at it's maximum extension at 52mm which means, for instance, that it's possible to adjust it correctly for a Technics S-arm but only for Stevenson. Baerwald would be right out.
I drilled out the slots on one of my less valuable headshells to get this thing into a baerwald. Some of my headshells couldn't even reach a Stevenson on the AT arm. This cart places the stylus practically underneath the mounting holes so you really need some decently long slots!
Sounds good so far, haven't run any actual channel balance/separation tests yet. VTA is definitely looking a bit better than it did on my last table, I have a spacer under the cart to get the arm riding a bit higher.
I'll get out my test record and reevaluate the channel separation issue with the new setup tomorrow.
Cheers,
Nathan
Oh! I have one of those and it seemed to be okay tracking tough vocal sibilants. Which record is giving it trouble? Maybe I need to find a tougher test record.
It's actually the same track that gives a bit of sibilance on the Ortofon FF15xe MkII I've been playing with. "Save Yourself" on side B of Kaleo's A/B.
I put the AT95HE back on and only heard it the tinest bit on one line.
The cart is not broken in yet, not sure how much improvement I can expect on that front.
Hm. Must be tough if the generic AT95HE won't track it, at least if yours is the same stylus as the 710-HE I got from Gary a few months back.
