Piezo-Azden-Acutex Thread
I assume that the rough spot is in the climax near the end of the track and that you've tried it at 2g or more. Interesting.
On one of my new styli u put a drop of Radio Shack Tuner cleaner and lube on the suspension for an hour then used compressed air to blow the rest out.
it softened up the suspension some. It might just need to get worked in Nate.
Nashou
What are the chances that the initial mistracking I heard with the Ortofon carved that sound into the record and I hear it less with the AT cart because it has a different stylus profile?
Acutex M307IIE there is another replacement by Walco W-718STDE its an elliptical but I cant seem to find out what tip it is. 2x7 3x7 4x7 a few sellers I contacted on ebay and they dont have a clue what tip it is! And its made in Japan? Anybody? Is the only decent replacement the yellow bodied one?
Most are .0004 x .0007 elliptical. Make sure they have the metal shield on the underside other wise they don't have the third pole magnet which is what makes it a Tri-Pole design .
Nashou
I bought one of the Walcos for the 315II STR. They appear to be Japanese. Unlike the originals, it's an elliptical rather than a line contact, probably an 0.3 x 0.7. (My guess is they all are, the only difference being the grip color.) They have both the shield and the soft iron sleeve at the base of the cantilever so they're true tri-pole styli unlike the black 4707-DE which is actually an AT type V-magnet stylus. It's a pretty decent stylus, better than the yellow 707-DE.
This thread has been dead for awhile So I'm bringing it back up in the queue :D
Listening the that Concord MC I got a few years ago. Sound better on my AR XA than on the sota from what I remember !!
WOW what a sound stage!!!
Thanks it sounds awesome!!
Nashou
These are really good news for me: if your M320 sounds awesome coming from 1978, I think that NOS replacement needles for my long nose LPM M312IIISTR coming from 1980 that I'm waiting for in my mail-box should sound ok as well. Congratulations,I hope I have the same luck as you someday, in the meanwhile I keep on hunting for a 320.
It does sound awesome but after a few hours of playing I noticed it beginning to get closer to the record .
So the suspension is giving out. I put it on right away from the mailbox where it was 25° so I think after it warmed up it began to loose its stiffness.
It still sounds great though . SO i took it off and gave it a very careful targeted application of WD 40 in hopes it will revive
the foam suspension. I also wedged a piece of lead wire from resistors to put it into a more sharp angle while the WD 40 does its job....hopefully .
Well see later tonight how it fared. If it doesn't work I'll just keep it frozen and pull it out for a couple hours of listening when I want to hear
it :D Seems the cold kept the suspension stiff where it worked well.
But if the suspension is shot I might try to take one from a replacement and use that.
But the 320 suspension looks different than any of the others i have seen, its white where most others I have looked at are black.
Maybe that was part of the difference of the 315 ton the 320?
Who has a Brick 315 stylus to let me know what color the suspension foam/rubber is?
Athanasios
Those actually have a tension screw just like an Audio-Technica or a moving coil cartridge. You might try to loosen the screw, push the cantilever toward the cushion a little and then tighten the screw again in order to increase tension. It might improve things.
Yes I Have done this before. That was my next step.
Nashou
Fingers crossed.
Got it a little better . It is at least back to where it was on my first play. The stylus guard is about 1.5 mm from the record .
Where after a few hours it was at .75 mm from the record .
I could probably get more but didn't want to push it. Its delicate work.
So for now It sounds great with no adverse sonic affects.
here is a pic, still low but it was worse.
That is a LOW rider for sure. Can you back off the tracking force any? I thought I remembered the bricks tracking really low, like 3/4 - 1.25 grams?
