Piezo-Azden-Acutex Thread
I picked up the last one a minute ago as a spare for my LPM-320. I never thought I would see another NOS 320 stylus. Now I don't have to worry so much about using my LPM for fear of wearing it out. I really enjoy these Acutex cartridges.
Awesome !!!!
Might as well get some 312's too . Use it for when you don't want to use the 320.
25% the cost of the one you bought !
Nashou
Exactly! This chance at a fair price surely won’t come around again. Congratulations we had a nice little feeding frenzy there did we not?
Indeed! I missed the first round. I did manage to pick up a couple of the shibata style Eagle branded styli for the Acutex bricks a while back. I think I am fixed for Acutex nails - at least for the foreseeable future.
Scary good considering it’s got just 1 short (45rpm LP) side on it. I left the VTA where it was, so it’s dragging it’s tail a bit which generally suits me.
Good idea I’m getting distortion on the Guaraldi’s piano. I’ll level it out tomorrow. I assume the back half of the snout is the correct reference surface.
I found this Empire SLM444 on a trashed RadioShack TT. I've read that it's a rebadged Piezo YM-125 and that it doesn't track very well.
It sounds pretty good to me, and I haven't had any tracking issues on my Pioneer PL-530.
Update: The 320 is breaking in quite nicely. I’m tempted to declare it done after only 14 albums. After setting VTA to level, I increased the TF to 1.8 and any hint of distortion disappeared. The tripole design is very effective a noise canceling as even the magic eraser pre-play dip is silent at my normal volume. These are truly special cartridges.
I run mine at 1.8 too, ( the 312&315 ). I think the 312 is a really nice listen. Pretty hard to call it bottom of the heap.
I agree, they are all very nice styli. The 312 is rough cut, the 315 I think is polished but bonded and the 320 is polished and nude mount.
All very similar, hard to tell them apart really.
Athanasios
Also my needles from Canada arrived without a problem, now i'm doing the breaking in of the first 315 stylus: it sounds perfectly, after a breaking in period of at least ten hour I'll compare it with 312ACUTEX REPLACEMENT NEEDLE.jpg ACUTEX NEEDLE 315 IN ACTION .jpg
Also my needles from Canada arrived without a problem, now i'm doing the breaking in of the first 315 stylus: it sounds perfectly, after a breaking in period of at least ten hour I'll compare it with 312View attachment 2108008 View attachment 2108009
Awesome !!! See and you were worried about getting duds ;)
One thing I read somewhere is these acutex like being loaded at 100k So if you can change load resistance on your phon o stage or use parallel loading try it out ands see what ya think.
Athanasios
Athanasios
Ehm, the problem is that I'm using the phonostage integrated in my little "genius" amplifier Grundig V20: believe it or not I have compared it with two phono preamp lended by two friend of mine (one was a Goldnote Ph1 - price 600 € and the second was selfmade completely configurable in loading and capacitance) but the V20 was the winner twice, thus I decided not to buy one.
According to my personal taste the Acutex has a wonderful sound even if loaded with 400 pf of capacitance and 47 kohm (just like suggested for my previous vintage Shures).
At the moment I could think only to lower the capacitance changing the phono cable, but nothing else, unless it's possible to apply parallel loading directly to phono Rca on the amplifier.
Got it a little better . It is at least back to where it was on my first play. The stylus guard is about 1.5 mm from the record .
Where after a few hours it was at .75 mm from the record .
I could probably get more but didn't want to push it. Its delicate work.
So for now It sounds great with no adverse sonic affects.
here is a pic, still low but it was worse.
Update.
I added a tiny drop of WD-40 off a dental pick tool and now after a month or so its stiffened up the suspension to the right point, so much so I dont have to tip toe in my listening room
to keep it from skipping. I can walk normally and the AR's suspension along with the now stiffer M320 suspension is doing fine.
Its sounding quite nice I must say !
How are your guys NOS LPM styli doing? I advent been using them yet , enjoying the 320 brick too much for now.
Athanasios
Update.
Athanasios
In the last two month I had a very little time to listen to my NOS stylus arrived from Canada (two 315 and a 312): After a break in period of 6-7 hour for the first stylus I was not fully glad about the sound, there was something different in the midrange: they seemed to me not as clear as in the original that came with the 312 cartridge.
So I decided to begin to listen to the second 315 stylus arrived: after 6-7 hour of break-in period I had the same sensation about the first one. Then I decided to compare it with the CD: I have only three album that I bought either in CD or in Vinyl: one of them is "Just another way to say I love you" by Barry White that to my ears sounds better in vinyl because there is an exaggerated boost in low frequencies in the CD equalization.
When at last yesterday I compared the second 315 stylus with the CD I was highly disappointed: the midrange tone range was clearly different: worse stereo separation, that ended in a more "confused" sound: then I tried the first 315 stylus but the result was exactly the same: but when I tried the original 312 stylus (that has at least 400 working hours on the shoulders) all the magnificent glory of the Acutex 312 cartridge was here: this album returned to sound better in vinyl, same stereo separation of the CD, but better balnced sound without the abnormal boost on the low frequencies that affected also the midrange tones, diminuishing their clarity and transparence.
I decided to try for the very first time also the 312 NOS stylus arrived from Canada: It sounded perfect as the original used 312 from the very first track: who knows, it can happen that it could also sound better than original used one after a break-in period.
The bad thing is that I have two 315 stylus that are unuseful to me, I would have been better off buying three 312 stylus instead of two 315 and only a 312 ones.
The only thing I can do is to keep on with the break-in period of the two 315 stylus hoping in an unlikely improvement in sound, the 312 sounded wonderful ad dropped in the vinyl.
Nevertheless I am not able to understand why the two 315 are worse than 312 ones, they were supposed at least to be slightly better.
They probably need a longer break in . Just keep using them, they will get better.
Also these carts like to be loaded at 100k Give that a try if you can as well.
Another, Also, is these need to be set up perfectly. Play around with VTA, VTF Azimuth etc.
It will take time, and like you said the break in will be the best thing. Increase VTF for about 20 hours to over 2 grm's .
I suspect the suspension is too stiff from years of sitting. If break in does not work add a very very small drop of WD-40 on the rubber doughnut att he base of the cantilever. Let it sit for a day or two. This worked with my 320 brick.
Athanasios
